Defining Maintenance Managers
The Maintenance Manager portal is used to display and maintain maintenance managers.
You can access the portal from Admin, select M, then select Maintenance Manager.
  • Maintenance Manager List: This zone lists all maintenance manager records. Broadcast a record to display the details of the selected record.
  • Maintenance Manager: This zone provides information about the selected maintenance manager.
