Defining Service History Questions
The Service History Question portal is used to display and maintain condition assessment questions.
You can access the portal from Admin, select S, then select Service History Question. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Service History Question: This zone provides information on question and answers for conditional assessments.
- Service History List: This zone displays a list of associated service history types.
