Example
The following table provides examples of the types of roles you may need to create in order to support your approval hierarchy:
Admin Object | Example of Data to Create |
To Do Types |
These default types are delivered with the base package
with the ToDo Type Usage set to Automatic:
To Do Role |
User Groups |
Approval Profiles |
Using a scenario of a moderate structure with a separate approval profile for each document type, refer to the following table for an example of the hierarchy:
Seq | To Do Role | Approval Type | Initial Notification Method | Amount Limit | Time Out Threshold | Maximum Retry |
10 | Supervisor | Standard | To Do List Only | $1000 | 2 (days) | 1 (retry) |
20 | General Manager | Mandatory | Both (email and To Do List) | $5000 | 2 (days) | 2 (retries) |
This example establishes a hierarchy where the first role to receive the approval request is at the supervisor level with a minimal approval limit. This supervisor would approve the request only to inform the general manager that they approve, but since the General Manager has been set with a mandatory approval type, the General Manager must approve the request for the processing to be considered complete.
