Maintaining Bill of Materials
The Bill of Materials portal is used to display and maintain a bill of material record.
Refer to About Material Disposition for more information.
You can access the portal from Menu, select Asset Management, then select Bill of Materials. You are brought to a query portal with options for searching for a specific bill of material. Once a bill of material has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- BOM Tree: This zone displays a hierarchy view of the selected BOM and BOM parts.
- Bill of Materials: This zone displays information about the bill of material record.
- Referencing BOM’s: This zone lists the BOMs that reference this particular BOM record.
- Attachments: This zone enables users to manage all types of attachments for the BOM record.
- Notes: This zone displays any notes associated with the bill of material record.
