Maintenance Object: Bill Segment
This section contains the sample SQL for the following tables:
Parent Table: CI_BSEG
CREATE BIGFILE TABLESPACE CM_XT048_P2017JAN DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017FEB DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017MAR DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017APR DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017MAY DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017JUN DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017JUL DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017AUG DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017SEP DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017OCT DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017NOV DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_P2017DEC DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE BIGFILE TABLESPACE CM_XT048_PMAX DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED
CREATE TABLE CI_BSEG
BSEG_ID CHAR(12) NOT NULL,
BILL_CYC_CD CHAR(4) DEFAULT ' ' NOT NULL,
WIN_START_DT DATE,
CAN_RSN_CD CHAR(4) DEFAULT ' ' NOT NULL,
CAN_BSEG_ID CHAR(12) DEFAULT ' ' NOT NULL,
SA_ID CHAR(10) DEFAULT ' ' NOT NULL,
BILL_ID CHAR(12) DEFAULT ' ' NOT NULL,
START_DT DATE,
END_DT DATE,
EST_SW CHAR(1) DEFAULT ' ' NOT NULL,
CLOSING_BSEG_SW CHAR(1) DEFAULT ' ' NOT NULL,
SQ_OVERRIDE_SW CHAR(1) DEFAULT ' ' NOT NULL,
ITEM_OVERRIDE_SW CHAR(1) DEFAULT ' ' NOT NULL,
PREM_ID CHAR(10) DEFAULT ' ' NOT NULL,
BSEG_STAT_FLG CHAR(2) DEFAULT ' ' NOT NULL,
CRE_DTTM DATE,
STAT_CHG_DTTM DATE,
REBILL_SEG_ID CHAR(12) DEFAULT ' ' NOT NULL,
VERSION NUMBER(5,0) DEFAULT 1 NOT NULL,
MASTER_BSEG_ID CHAR(12) DEFAULT ' ' NOT NULL,
QUOTE_DTL_ID CHAR(12) DEFAULT ' ' NOT NULL,
BILL_SCNR_ID CHAR(12) DEFAULT ' ' NOT NULL,
MDM_START_DTTM DATE,
MDM_END_DTTM DATE,
BSEG_DATA_AREA CLOB,
ILM_DT DATE,
ILM_ARCH_SW CHAR(1))
ENABLE ROW MOVEMENT
PARTITION BY RANGE (ILM_DT)
SUBPARTITION BY RANGE (BSEG_ID) SUBPARTITION TEMPLATE (
SUBPARTITION S01 VALUES LESS THAN ( '124999999999' ),
SUBPARTITION S02 VALUES LESS THAN ( '249999999999' ),
SUBPARTITION S03 VALUES LESS THAN ( '374999999999' ),
SUBPARTITION S04 VALUES LESS THAN ( '499999999999' ),
SUBPARTITION S05 VALUES LESS THAN ( '624999999999' ),
SUBPARTITION S06 VALUES LESS THAN ( '749999999999' ),
SUBPARTITION S07 VALUES LESS THAN ( '874999999999' ),
SUBPARTITION S08 VALUES LESS THAN ( MAXVALUE )
PARTITION "P2017JAN" VALUES LESS THAN (TO_DATE('2017-02-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017JAN,
PARTITION "P2017FEB" VALUES LESS THAN (TO_DATE('2017-03-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017FEB,
PARTITION "P2017MAR" VALUES LESS THAN (TO_DATE('2017-04-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017MAR,
PARTITION "P2017APR" VALUES LESS THAN (TO_DATE('2017-05-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017APR,
PARTITION "P2017MAY" VALUES LESS THAN (TO_DATE('2017-06-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017MAY,
PARTITION "P2017JUN" VALUES LESS THAN (TO_DATE('2017-07-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017JUN,
PARTITION "P2017JUL" VALUES LESS THAN (TO_DATE('2017-08-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017JUL,
PARTITION "P2017AUG" VALUES LESS THAN (TO_DATE('2017-09-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017AUG,
PARTITION "P2017SEP" VALUES LESS THAN (TO_DATE('2017-10-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017SEP,
PARTITION "P2017OCT" VALUES LESS THAN (TO_DATE('2017-11-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017OCT,
PARTITION "P2017NOV" VALUES LESS THAN (TO_DATE('2017-12-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017NOV,
PARTITION "P2017DEC" VALUES LESS THAN (TO_DATE('2018-01-01 00:00:01', 'SYYYY-MM-DD HH24:MI:SS', 'NLS_CALENDAR=GREGORIAN'))
tablespace CM_XT048_P2017DEC,
PARTITION "PMAX" VALUES LESS THAN (MAXVALUE)
tablespace CM_XT048_PMAX
CREATE BIGFILE TABLESPACE CM_XT048_IND DATAFILE '+DATA' SIZE 100M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED;
INDEX
CREATE UNIQUE INDEX XT048P0 ON CI_BSEG ( BSEG_ID ) TABLESPACE CM_XT048_IND
GLOBAL PARTITION BY RANGE (BSEG_ID)
PARTITION P1 VALUES LESS THAN ( '124999999999' ),
PARTITION P2 VALUES LESS THAN ( '249999999999' ),
PARTITION P3 VALUES LESS THAN ( '374999999999' ),
PARTITION P4 VALUES LESS THAN ( '499999999999' ),
PARTITION P5 VALUES LESS THAN ( '624999999999' ),
PARTITION P6 VALUES LESS THAN ( '749999999999' ),
PARTITION P7 VALUES LESS THAN ( '874999999999' ),
PARTITION P8 VALUES LESS THAN ( MAXVALUE )
ALTER TABLE CI_BSEG ADD CONSTRAINT XT048P0 PRIMARY KEY(BSEG_ID) USING INDEX
CREATE INDEX XT048S1 ON CI_BSEG ( BILL_ID ) TABLESPACE CM_XT048_IND
CREATE INDEX XT048S2 ON CI_BSEG ( SA_ID ) TABLESPACE CM_XT048_IND
CREATE UNIQUE INDEX XT048S3 ON CI_BSEG ( QUOTE_DTL_ID, BSEG_ID )TABLESPACE CM_XT048_IND COMPRESS ADVANCED LOW
CREATE UNIQUE INDEX CM_ILM_XT048L0 ON CI_BSEG ( ILM_DT, ILM_ARCH_SW, BSEG_ID ) TABLESPACE CM_XT048_IND LOCAL COMPRESS ADVANCED LOW
Child Table: CI_BSEG_CALC
CREATE TABLE CI_BSEG_CALC
BSEG_ID CHAR(12) NOT NULL ENABLE,
HEADER_SEQ NUMBER(3,0) NOT NULL ENABLE,
START_DT DATE NOT NULL ENABLE,
CURRENCY_CD CHAR(3) DEFAULT ' ' NOT NULL ENABLE,
END_DT DATE NOT NULL ENABLE,
RS_CD CHAR(8) DEFAULT ' ' NOT NULL ENABLE,
EFFDT DATE,
BILLABLE_CHG_ID CHAR(12) DEFAULT ' ' NOT NULL ENABLE,
CALC_AMT NUMBER(15,2) DEFAULT 0 NOT NULL ENABLE,
DESCR_ON_BILL VARCHAR2(254) DEFAULT ' ' NOT NULL ENABLE,
VERSION NUMBER(5,0) DEFAULT 1 NOT NULL ENABLE,
CONSTRAINT CI_BSEG_CALC_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_CALC_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT072P0 ON CI_BSEG_CALC ( BSEG_ID, HEADER_SEQ ) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_CALC ADD CONSTRAINT XT072P0 PRIMARY KEY(BSEG_ID, HEADER_SEQ) USING INDEX
CREATE INDEX XT072S1 ON CI_BSEG_CALC ( BILLABLE_CHG_ID, BSEG_ID ) TABLESPACE CM_XT048_IND COMPRESS ADVANCED LOW
Child Table: CI_BSEG_CALC_LN
CREATE TABLE CI_BSEG_CALC_LN
SEQNO NUMBER(5,0) NOT NULL ENABLE,
CHAR_TYPE_CD CHAR(8) DEFAULT ' ' NOT NULL ENABLE,
CHAR_VAL CHAR(16) DEFAULT ' ' NOT NULL ENABLE,
DST_ID CHAR(10) DEFAULT ' ' NOT NULL ENABLE,
UOM_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
TOU_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
RC_SEQ NUMBER(4,0) DEFAULT 0 NOT NULL ENABLE,
PRT_SW CHAR(1) DEFAULT ' ' NOT NULL ENABLE,
APP_IN_SUMM_SW CHAR(1) DEFAULT ' ' NOT NULL ENABLE,
EXEMPT_AMT NUMBER(15,2) DEFAULT 0 NOT NULL ENABLE,
BASE_AMT NUMBER(15,2) DEFAULT 0 NOT NULL ENABLE,
SQI_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
BILL_SQ NUMBER(18,6) DEFAULT 0 NOT NULL ENABLE,
MSR_PEAK_QTY_SW CHAR(1) DEFAULT ' ' NOT NULL ENABLE,
AUDIT_CALC_AMT NUMBER(18,5) DEFAULT 0 NOT NULL ENABLE,
CALC_GRP_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
CALC_RULE_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
CONSTRAINT CI_BSEG_CALC_LN_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_CALC_LN_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT050P0 ON CM_BSEG_CALC_LN ( BSEG_ID, HEADER_SEQ,SEQNO) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_CALC_LN ADD CONSTRAINT XT050P0 PRIMARY KEY(BSEG_ID, HEADER_SEQ,SEQNO) USING INDEX
Child Table: CI_BSEG_CL_CHAR
CREATE TABLE CI_BSEG_CL_CHAR
CHAR_TYPE_CD CHAR(8) NOT NULL ENABLE,
ADHOC_CHAR_VAL VARCHAR2(254) DEFAULT ' ' NOT NULL ENABLE,
CHAR_VAL_FK1 VARCHAR2(50) DEFAULT ' ' NOT NULL ENABLE,
CHAR_VAL_FK2 VARCHAR2(50) DEFAULT ' ' NOT NULL ENABLE,
CHAR_VAL_FK3 VARCHAR2(50) DEFAULT ' ' NOT NULL ENABLE,
CHAR_VAL_FK4 VARCHAR2(50) DEFAULT ' ' NOT NULL ENABLE,
CHAR_VAL_FK5 VARCHAR2(50) DEFAULT ' ' NOT NULL ENABLE,
CONSTRAINT CI_BSEG_CL_CHAR_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_CL_CHAR_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT056P0 ON CI_BSEG_CL_CHAR ( BSEG_ID, HEADER_SEQ, SEQNO, CHAR_TYPE_CD ) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_CL_CHAR ADD CONSTRAINT XT056P0 PRIMARY KEY(BSEG_ID, HEADER_SEQ, SEQNO, CHAR_TYPE_CD) USING INDEX
Child Table: CI_BSEG_EXCP
CREATE TABLE CI_BSEG_EXCP
MESSAGE_CAT_NBR NUMBER(5,0) DEFAULT 0 NOT NULL ENABLE,
MESSAGE_NBR NUMBER(5,0) DEFAULT 0 NOT NULL ENABLE,
BSEG_EXCP_FLG CHAR(2) DEFAULT ' ' NOT NULL ENABLE,
EXP_MSG VARCHAR2(254) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM1 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM2 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM3 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM4 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM5 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM6 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM7 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM8 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
MESSAGE_PARM9 VARCHAR2(2000) DEFAULT ' ' NOT NULL ENABLE,
CALL_SEQ VARCHAR2(254) DEFAULT ' ' NOT NULL ENABLE,
USER_ID CHAR(8) DEFAULT ' ' NOT NULL ENABLE,
CRE_DTTM DATE,
REVIEW_COMP CHAR(1) DEFAULT ' ' NOT NULL ENABLE,
REVIEW_USER_ID CHAR(8) DEFAULT ' ' NOT NULL ENABLE,
REVIEW_DT DATE,
COMMENTS VARCHAR2(254) DEFAULT ' ' NOT NULL ENABLE,
CONSTRAINT CI_BSEG_EXCP_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_EXCP_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT051P0 ON CI_BSEG_EXCP ( BSEG_ID ) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_EXCP ADD CONSTRAINT XT051P0 PRIMARY KEY(BSEG_ID) USING INDEX
Child Table: CI_BSEG_MSG
CREATE TABLE CI_BSEG_MSG
BILL_MSG_CD CHAR(4) NOT NULL ENABLE,
CONSTRAINT CI_BSEG_MSG_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_MSG_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT080P0 ON CI_BSEG_MSG ( BSEG_ID, BILL_MSG_CD ) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_MSG ADD CONSTRAINT XT080P0 PRIMARY KEY(BSEG_ID, BILL_MSG_CD) USING INDEX
Child Table: CI_BSEG_READ
CREATE TABLE CI_BSEG_READ
SP_ID CHAR(10) NOT NULL ENABLE,
REG_CONST NUMBER(12,6) DEFAULT 0 NOT NULL ENABLE,
USAGE_FLG CHAR(2) DEFAULT ' ' NOT NULL ENABLE,
USE_PCT NUMBER(5,2) DEFAULT 0 NOT NULL ENABLE,
HOW_TO_USE_FLG CHAR(2) DEFAULT ' ' NOT NULL ENABLE,
START_REG_READ_ID CHAR(12) DEFAULT ' ' NOT NULL ENABLE,
START_READ_DTTM DATE NOT NULL ENABLE,
START_REG_READING NUMBER(15,6) DEFAULT 0 NOT NULL ENABLE,
END_REG_READ_ID CHAR(12) DEFAULT ' ' NOT NULL ENABLE,
END_READ_DTTM DATE NOT NULL ENABLE,
END_REG_READING NUMBER(15,6) DEFAULT 0 NOT NULL ENABLE,
MSR_QTY NUMBER(18,6) DEFAULT 0 NOT NULL ENABLE,
FINAL_UOM_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
FINAL_TOU_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
FINAL_REG_QTY NUMBER(18,6) DEFAULT 0 NOT NULL ENABLE,
FINAL_SQI_CD VARCHAR2(30) DEFAULT ' ' NOT NULL ENABLE,
CONSTRAINT CI_BSEG_READ_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_READ_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT054P0 ON CI_BSEG_READ ( BSEG_ID, SP_ID, SEQNO ) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_READ ADD CONSTRAINT XT054P0 PRIMARY KEY(BSEG_ID, SP_ID, SEQNO) USING INDEX
CREATE INDEX XT054S1 ON CI_BSEG_READ ( SP_ID ) TABLESPACE CM_XT048_IND
CREATE INDEX XT054S2 ON CI_BSEG_READ ( START_REG_READ_ID ) TABLESPACE CM_XT048_IND
CREATE INDEX XT054S3 ON CI_BSEG_READ ( END_REG_READ_ID ) TABLESPACE CM_XT048_IND
Child Table: CI_BSEG_SQ
CREATE TABLE CI_BSEG_SQ
UOM_CD VARCHAR2(30) NOT NULL ENABLE,
TOU_CD VARCHAR2(30) NOT NULL ENABLE,
SQI_CD VARCHAR2(30) NOT NULL ENABLE,
INIT_SQ NUMBER(18,6) DEFAULT 0 NOT NULL ENABLE,
CONSTRAINT CI_BSEG_SQ_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_SQ_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT055P0 ON CI_BSEG_SQ ( BSEG_ID, UOM_CD, TOU_CD, SQI_CD ) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_SQ ADD CONSTRAINT XT055P0 PRIMARY KEY(BSEG_ID, UOM_CD, TOU_CD, SQI_CD) USING INDEX
Child Table: CI_BSEG_ITEM
CREATE TABLE CI_BSEG_ITEM
ITEM_TYPE_CD VARCHAR(30) DEFAULT ' ' NOT NULL ENABLE,
ITEM_ID CHAR(10) DEFAULT ' ' NOT NULL ENABLE,
ITEM_CNT NUMBER(11,2) DEFAULT 0 NOT NULL ENABLE,
SVC_QTY NUMBER(18,6) DEFAULT 0 NOT NULL ENABLE,
CONSTRAINT CI_BSEG_ITEM_FK FOREIGN KEY(BSEG_ID) REFERENCES CI_BSEG ON DELETE CASCADE
PARTITION BY REFERENCE (CI_BSEG_ITEM_FK)
ENABLE ROW MOVEMENT
INDEX
CREATE UNIQUE INDEX XT053P0 ON CI_BSEG_ITEM ( BSEG_ID, SEQNO ) TABLESPACE CM_XT048_IND
ALTER TABLE CI_BSEG_ITEM ADD CONSTRAINT XT053P0 PRIMARY KEY(BSEG_ID, SEQNO) USING INDEX
