Requirements by Tier
The application is deployed on multiple Tiers:
• Tier 1, Desktop
• Tier 2, Web/Business Application Server
• Tier 3, Database Server
Tier 1, Desktop: Software and Hardware Requirements
The web browsers listed below are supported when used on each of the operating systems indicated:
Browser
Windows Operating System
Microsoft Edge for Business (Edge Chromium)
Microsoft Windows 10 and 11 Version x (64-bit)
Mozilla Firefox ESR 115.x
Google Chrome Enterprise
Apple Mobile Safari
Apple iPad iOS 17.x
Make sure that your system meets the following recommended hardware requirements.
Configuration
Processor
Memory (RAM)
Minimum
Pentium IV - 2.0 GHz
1024 MB
Recommended
Pentium IV - 3.0+ GHz or any Core 2 Duo or any Athlon X2
2048MB
Minimum monitor display size: 1920 X 1080
Tier 2, Web/Business Application Server: Software and Hardware Requirements
Refer to Supported Platforms to determine which web application servers can be used with the operating system that will be hosting this tier.
The recommendations that follow are based on a standard installation with both the web application and business application servers on the same machine and the system running with the default values. The default values may not support a production environment. You should adjust these values according to your production needs. Refer to the Server Administration Guide on how to change the default values. The minimum resource requirements exclude third-party software installation requirements. Refer to the third- party vendors for specific requirements. The following sizing excludes the Oracle database server installation.
Tier 3, Database Server: Software and Hardware Requirements
Refer to Supported Platforms for information about the supported database servers.
