Defining Message Categories
This portal is used to view and maintain a message category and its messages.
CAUTION: Message category 80000 or greater must be used
to define new messages introduced for a specific implementation of
the system. Changes to other Message Text will be overwritten when
you next upgrade. If you want to make a change to a Message, drill
down on the message and populate the Override Message Text. Note that
even for message categories 80000 and higher, message numbers lower
than 1000 are reserved for common base product messages.
You can access the portal from the
. You are brought to a query portal with options for searching for a specific message category or a specific message. Once a message category has been selected you are brought to the maintenance portal to view and maintain the selected record.Refer to Understanding System Messages for more information.
The following zones may appear as part of the portal's Main tab page
- Message Category. This zone provides information about the selected message category.
- Messages. This zone lists and maintains messages for the selected category.
