User - Favorite Scripts
This page is used to define a user's favorite scripts. Each script is displayed in the Favorite Scripts zone on the Sidebar where it can be used to initiate a script.
A hot key can be used to execute a favorite script.
Rather than selecting a script from the business process assistant,
you can invoke your first nine favorite scripts by pressing Ctrl + Shift + a number (where the number corresponds
with the relative position of the script in your list of favorites).
Note that the numeric keypad on your keyboard cannot be used to implement
this function.
Open the User page and then navigate to the Favorite Scripts tab to modify a user’s Favorite Scripts.
Description of Page
You may not be able to change your favorite scripts. If
a Note is displayed on top of the grid, your
user id has been setup to reference a specific Favorites
Profile User as defined on the Main tab. If a system administrator has setup your user ID in this way,
your preferences may not be changed. System administrators may apply
this feature in order to enforce a common look-and-feel throughout
the user community.
Each row in the grid contains one of your favorite Scripts.
Use the Sort Sequence to control the order in which the scripts appear in the business process assistant menu.
Security Access indicates whether you have access to the script's application service. Refer to The Big Picture Of Application Security for more information.
