Batch Submission Creates a Batch Run
When you request a batch job to be submitted from on-line, the execution of the desired background process will result in the creation of a batch run. Just as with background processes executed through your scheduler, you may use the Batch Run Tree page to view the status of the run, the status of each thread, the run-instances of each thread, and any messages that might have occurred during the run.
Note: Your on-line submission record is assigned a status value so
that you may know whether your job has been submitted and whether
or not it has ended, however, it will not contain any information
about the results of the background process itself. You must navigate
to the Batch Run
Tree page to view this detail.
