Defining Employee Unavailability Types
The Employee Unavailability Type portal is used to display and maintain employee unavailability types.
You can access the portal from Admin, select E, then select Employee Unavailability Type.
  • Employee Unavailability Type List: This zone lists all employee unavailability type records. Broadcast a record to display the details of the selected record.
  • Employee Unavailability Type: This zone provides information about the selected unavailability type.
