Defining Organization Types
The Organization Type portal is used to display and maintain organization types.
You can access the portal from Admin, select O, and then select Organization Type.
  • Organization Type List: This zone lists all organization type records. Broadcast a record to display the details of the selected record.
  • Organization Type: This zone displays information about the selected organization type.
