Valid Attributes
For simple use cases where additional details about an asset need to be captured and these details vary by asset type, you may define these details as asset-related characteristic types and associate them with each asset type as needed. With this simplified extension method, the base asset BOs may be used as is without any schema change.
Implemented as a characteristic, the value of such asset attributes may only be of a free text or restricted to a predefined list of characteristic values.
Use the following steps to guide configuration:
- Consider what attributes you want to have recorded for each of your asset types. For example, Pole asset type attributes might include Set Year, Material, Material Class, and Current Height.
- Define a characteristic type of the appropriate type value. Use a Predefined Value Characteristic Type for a list of valid values and an Adhoc Value Characteristic Type for a simple text value. Link the Characteristic Type to the Asset Attributes (W1–AssetAttributes) entity.
- Associate each attribute with the asset types it is applicable
to. Assets created from the asset type will display the list of asset
attributes in the Asset Attributes zone on the Asset record.Note: Asset Attributes zone will only display on the Asset record if the Asset Type it was created from includes at least one asset attribute.
- Consider whether your business process requires validation algorithms to be plugged in on the asset business object to further validate or enforce other business rules related to these asset attributes.
