Maintaining Specifications
This portal is used to display and maintain specification records.
Refer to About Assets for more information.
You can access the portal from Menu, select Asset Management, then select Specification. You are brought to a query portal with options for searching for a specific specification. Once the specification has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Specification: This zone provides details about the specification.
  • Warranty Term: This zone lists the warranty terms associated with the specification.
  • Specification Assets: This zone provides information about the asset associated with the specification.
  • Attachments: This zone enables users to manage all types of attachments for the specification record.
