Preparing the Staging Database
After the staging owner (STGADM), application user (STGUSER) and read access user (STGREAD) are created, install the initial database option in the staging schema. The rest of the steps are listed below.
To run the utility:
1. Set JAVA_HOME, PATH, and CLASSPATH.
For ADB, make sure the database connection is working. For more information, see step 1.b.a.c in the Creating the Database section and export/SET TNS_ADMIN=<wallet location>.
Linux/UNIX:
export JAVA_HOME=/scratch/software/jdk/
export PATH=$JAVA_HOME/bin:$PATH
export CLASSPATH=/../FW-V25.10-Oracle-Database- Multiplatform/FW/jarfiles/*
Windows:
SET JAVA_HOME=C:\Program Files\Java\jdk
SET PATH=%JAVA_HOME%\bin:%PATH%
SET CLASSPATH= C:\FW-V25.10-Oracle-Database- Multiplatform\FW\jarfiles\*
2. Run Conversion from any directory making sure Step 1 is complete. Run the command as necessary.
Note: Execute the following command as ADMIN for ADB:
grant dwrole to STGADM;
grant dwrole to STGUSER;
grant create any view to STGUSER;
Linux/UNIX:
If '-a' (apply on staging flag) is passed, it connects to the database as staging schema admin and performs the conversion setup, in addition to creation of the above files, by running the same SQLs present in the create* SQL files.
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -a -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -a -s
If '-r' (revert staging flag) is passed, it connects to the database as staging schema admin and reverts the staging to a state prior to conversion setup, running the same SQLs present in drop_* or restore_* SQL files.
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -r -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -r -s
To generate ONLY the scripts, the program should be invoked with '-s' parameter with no other flags (no '-a' or '-r' ):
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -s
Windows:
On-premises:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -a -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
ADB:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -a -s
On-premises:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -r -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -r -s
On-premises:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -s
It creates the following files in current directory (or output directory if passed as '-o') if '-r' (revert staging flag) is not passed.
Filename
Description
mainFile.sql
Contains instructions on the order and how to run the files
create_schgrants.sql
Grant read permissions on production schema objects to staging admin user
create_cxviews.sql
Creates Conversion X views on staging schema
create_ctlviews.sql
Create Production Control views on staging schema
createck_tbls.sql
Creates Conversion Key tables on staging schema
createck_pkix.sql
Creates primary indexes on Conversion key tables
createck_secix.sql
Creates secondary indexes on Conversion key tables
createcr_tbls.sql
Creates XML/CLOB Resolution tables on staging schema
create_stggrants.sql
Grants select, insert permissions on above created staging objects to staging read/write user
restore_ctltbls.sql
Restores Control tables
drop_cxviews.sql
Restored Conversion X views
drop_tables.sql
Restores CK & CR tables
After the staging schema has been set up, generate the security for the staging user following the steps in the Configuring Security section.
Linux/UNIX:
• On-premises:
java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec-d
<STAGING_DBUSER>,< STAGING_DBPASS>, jdbc:oracle:thin:@<DB_SERVER>:<PORT>/
<SID> -u <STAGING_RW_USER> -r <STAGING_RW_USER_ROLE>,< STAGING_R_USER_ROLE> -a A -p
<RW_USERPASS>
• ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -u <STAGING_RW_USER> -r <STAGING_RW_USER_ROLE>,< STAGING_R_USER_ROLE> -a A -p <RW_USERPASS>
Windows:
