Installing the Oracle Database
This section describes how to install the Oracle Database for Oracle Utilities Digital Asset Management V25.10. It includes the following:
Note that the installation tools outlined in this guide run on Windows and UNIX/Linux only. See the Supported Database Platforms section for more information on supported platforms.
Database Scripts and Utilities
Follow these steps before you begin installing the database. Installation scripts can be executed in a Linux/Windows machine with Oracle 19c installed.
Initial Install (Installing V25.10 for the First Time)
This section describes an initial installation of the V25.10 database. It focuses on the following:
Note: You must have a supported version of the Java Development Kit installed on the Windows desktop where you stage and run the database installation package. See the Oracle Utilities Digital Asset Management Installation Guide for more information.
Copying and Decompressing Install Media
To copy and decompress the Oracle Utilities Digital Asset Management database:
1. Download Oracle Utilities Digital Asset Management from Oracle Software Delivery Cloud (eDelivery).
• Oracle Utilities Application Framework V25.10 Oracle Database
• Oracle Utilities Application Framework V25.10 Single Fix Prerequisite Database Rollup for Oracle Utilities Digital Asset Management V25.10 (if there is any)
• Oracle Utilities Customer Care and Billing V25.10 Oracle Database
• Oracle Utilities Customer Care and Billing V25.10 Single Fix Database Rollup MultiPlatform (if there is any)
• Oracle Utilities Meter Data Management V25.10 Oracle Database
• Oracle Utilities Meter Data Management V25.10 Single Fix Database Rollup MultiPlatform (if there is any)
• Oracle Utilities Work and Asset Management V25.10 Oracle Database
• Oracle Utilities Work and Asset Management V25.10 Single Fix Database Rollup MultiPlatform (if there is any)
• Oracle Utilities Digital Asset Management V25.10 Oracle Database
• Oracle Utilities Digital Asset Management V25.10 Single Fix Database Rollup MultiPlatform (if there is any)
2. Copy and extract the downloaded zipped files to your local machine. These files include all the database components required to install the Oracle Utilities Application Framework and Oracle Utilities Digital Asset Management databases.
Database Creation
Note: You must have Oracle Database Server installed on your machine to create the database. This step is not required if you are performing a database upgrade from a previous version of Oracle Utilities Digital Asset Management or Oracle Utilities Customer Care and Billing, Oracle Utilities Meter Data Management, and Oracle Utilities Work and Asset Management to Oracle Utilities Digital Asset Management.
Creating the Database on UNIX
Create the database using the Database Configuration Assistant (DBCA).
See Creating the Database for steps to create the database.
Creating the Database on Windows
You should be logged in as a user who is a member of the local ORA_DBA group on that server. The ORA_DBA group should have “administrator” privileges assigned to it.
Database Globalization Support Consideration
Oracle Utilities Application Framework is a multilingual capable application that supports the storage, processing, and retrieval of data in multiple languages by leveraging the Oracle Database globalization support architecture. Use of the AL32UTF8 Unicode character encoding system allows the database to support multiple languages.
By default, the database is created with BYTE length semantics. This setting should be modified to use CHAR length semantics by setting NLS_LENGTH_SEMANTICS to CHAR at session level via a logon trigger during installation as shown below.
Example:
CREATE OR REPLACE TRIGGER RCU_INSTALL_TRIGGER after logon on database
declare
user_name varchar2(100);
begin
select user into user_name from dual;
if ( user_name LIKE 'CISADM' or user_name LIKE 'STG%' ) THEN
execute immediate 'alter session set nls_length_semantics=CHAR';
END IF;
END;
There are multiple ways to migrate a database from BYTE to CHAR length semantics:
• By script: For details, see Doc ID 313175.1 on My Oracle Support.
• Alternative procedure: Refer to the Initial Install section for steps to create a schema with char length semantics.
Initial Install
1. Create the database using DBCA. For instructions, see the Creating the Database section.
2. Run the following statement to set nls_length_semantics=CHAR.
SQL> ALTER SYSTEM SET nls_length_semantics=CHAR SCOPE=BOTH;
Note: Make sure to set nls_length_semantics=CHAR on the pluggable DB level only.
3. Restart the database.
4. Verify that the nls_length_semantics is CHAR using the following command:
SQL> SHOW PARAMETER nls_length_semantics
Extended Datatypes
Note: This step is applicable only for the on-premises databases. By default, ADB is set to EXTENDED.
Some of the Oracle Utilities Application Framework application table varchar2 fields require byte size beyond 4000 bytes to store data for new application requirements. To support this requirement OUAF database needs to make use of Extended Data Types - Oracle database 12c feature (EXTENDED means that the 32767 byte limit introduced in Oracle Database 12c applies.).
Enable the Extended Data Types by setting DB parameter, max_string_size = EXTENDED.
Follow the instructions provided in Oracle database documentation for including this change in your database.
Important! This change in your database environment is mandatory. If not included it will lead to errors during the V25.10 installation.
Enabling DBMS_CRYPTO Package
Before installing Oracle Utilities Application Framework V25.10 make sure to provide execute privilege on dbms_crypto package to CISADM user. Execute the following command as SYS for on-premises and ADMIN for ADB.
grant execute on dbms_crypto to CISADM;
Installing the CISADM Schema
Install Oracle Utilities Digital Asset Management in the order mentioned below:
The installation process prompts you for the following information:
• The target database name in which the product is to be installed.
• A database user that will own the application schema (Example: CISADM)
• A database user that has read-write (select/update/insert/delete) privileges to the objects in the application schema. (Example: CISUSER)
The application will access the database as this user.
• A database user with read-only privileges to the objects in the application schema. (Example: CISREAD)
• A database role that has read-write (select/update/insert/delete) privileges to the objects in the application schema. The application will access the database as this user. (Example: CIS_USER)
• A database role with read-only privileges to the objects in the application schema. (Example: CIS_READ)
• Location for jar files. (The Jar files are bundled with the database package.)
• Java Home (Example: C:\Java\jdk)
This section focuses on the following:
Installing the Oracle Utilities Application Framework Database Component
Note: The Oracle Utilities Application Framework database component can be installed using OraDBI.java. While prior versions of the product have included OraDBI.exe, this is no longer supported going forward as this does not support the latest functionality/features introduced in OraDBI.java.OraDBI.jar is delivered in directory jarfiles.
This section provides the instructions to install the database component.
Installing the Oracle Utilities Application Framework Database Component Using OraDBI.java
OraDBI.java is a tool to install and upgrade database components. It can be run from UNIX or Windows machines that has the following installed:
• Oracle 19c
• Oracle 19c client
Before installing the database component, make sure the following prerequisites are met.
• JDK 17
• Oracle Database
• Schema (such as CISADM) should exist in the database
• max_string_size is set to EXTENDED
• For ADB, the database connection should be working. For more information, seee step 1.b.a.c in the Creating the Database section.
To install Oracle Utilities Application Framework V25.10:
1. Unzip the Oracle Utilities Application Framework V25.10 Oracle Database package.
2. Set JAVA_HOME, CLASSPATH, and PATH.
Note: For ADB installation, export/SET TNS_ADMIN=<wallet location>.
UNIX:
export JAVA_HOME=/scratch/software/jdk/
export PATH=$JAVA_HOME/bin:$PATH
export CLASSPATH=/../../FW/jarfiles/*
WINDOWS:
SET JAVA_HOME=C:\Program Files\Java\jdk
SET PATH=%JAVA_HOME%\bin:%PATH%
SET CLASSPATH= C:\..\FW\jarfiles\*
3. Run the following command from the command line or command prompt from ..\FW\Install-Upgrade folder.
There are two options available to execute OraDBI.java:
• Using interactive mode
• Using command on command line
Using Interactive Mode
UNIX:
java -Xmx1500M com.oracle.ouaf.oem.install.OraDBI -p <RW_USERPASS>,<R_USERPASS>
WINDOWS:
“C:\Program Files\Java\jdk”\bin\java -Xmx1500M -cp C:\..\FW\jarfiles\* com.oracle.ouaf.oem.install.OraDBI -p <RW_USERPASS>,<R_USERPASS>
The utility prompts you to enter values for the parameters listed below:
• Enter the database server hostname:<SERVER NAME>
• Enter the database port number:<PORT>
• Enter the database name/SID:<DB NAME>
• Enter your database username:<CISADM>
• Enter your password for username CISADM:
• Enter the location for Java Home: <C:\Program Files\Java\jdk>
• Enter the Oracle user with read-write privileges to Database Schema:<CISUSER>
• Enter the Oracle user with read-only privileges to Database Schema:<CISREAD>
• Enter the database role with read-write privileges to Database Schema:<CIS_USER>
• Enter the database role with read-only privileges to Database Schema:<CIS_READ>
• Enter the name of the target Schema where you want to install or upgrade:<CISADM>
Using the Command Line:
UNIX:
• On-premises:
java -Xmx1500M com.oracle.ouaf.oem.install.OraDBI -d
jdbc:oracle:thin:@<DB_SERVER>:<PORT>/
<SID>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_USER_
ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
• ADB:
java -Xmx1500M com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_US
ER_
WINDOWS:
• On-premises:
“C:\Program Files\Java\jdk”\bin\java -Xmx1500M -cp C:\ ..\FW\jarfiles\* com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DB_SERVER>:<PORT>/ <SID>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_USER ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
• ADB:
“C:\Program Files\Java\jdk”\bin\java -Xmx1500M -cp C:\..\FW\jarfiles\* com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_US ER ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
This process generates log files in the directory ..\FW\Install-Upgrade\logs.
4. Make sure to check the log files for any errors.
Note: For OraDBI java, you may receive the following message in the display output or logs. These errors can be safely ignored and the process should proceed to completion.
- 2016-05-23 16:31:38,315 [main] ERROR (common.cryptography.KeyStoreWrapperFactory) The keystore file ‘<filename>’ does not exist.…
This file is either provided by the property com.oracle.ouaf.system.keystore.file or expected to exist at the default file location null Attempting to use the legacy cryptography.
- 2016-05-23 16:31:38,566 [main] INFO (oem.install.OraDBI)
Installing Oracle Utilities Application Framework Prerequisite Database Single Fixes
Before installing any edge products like Oracle Utilities Customer Care and Billing, Oracle Utilities Meter Data Management, Oracle Utilities Work and Asset Management and Oracle Utilities Digital Asset Management, you must install Oracle Utilities Framework Prerequisite Database Hot Fixes.
Important! Confirm if there are Prerequisite Database Single Fixes. Check if there is a C2M-V25.10-FW-Database-PREREQ-MultiPlatform folder. If none, skip this step and proceed to apply Oracle Utilities Customer Care and Billing.
Applying Hot Fixes
Note: Java 17 JDK should be installed on the machine to use the command. Ensure to install the JDK that is supported for your platform.
1. Extract db_patch_standalone.jar from Oracle Utilities Application Framework V25.10 Single Fix Prerequisite Database Rollup for C2M V25.10 package to any directory on your local machine under dbpatch_tools folder.
UNIX:
cd /../dbpatch_tools
jar xvf db_patch_standalone.jar
WINDOWS:
cd c:\..\dbpatch_tools
2. SET TOOLSBIN.
UNIX:
export TOOLSBIN=/../dbpatch_tools/bin
WINDOWS:
SET TOOLSBIN=c:\..\dbpatch_tools\bin
3. Apply prerequisite Framework DB single fixes from FW2510-HFix folder in Oracle Utilities Application Framework V25.10 Single Fix Prerequisite Database Rollup for C2M V25.10 package.
Note: For ADB, the database connection should be working. For more information, see step 1.b.a.c in the Creating the Database section and export/SET TNS_ADMIN=<wallet location>.
UNIX:
a. Change the permission of ouafDatabasePatch.sh tool.
chmod 755 ouafDatabasePatch.sh
b. Run the ouafDatabasePatch.sh tool.
sh ouafDatabasePatch.sh (or) ./ouafDatabasePatch.sh
WINDOWS:
Run the ouafDatabasePatch.cmd tool.
• Enter the target database type (O/M/D) [O]: <O>
• Enter the username that owns the schema: <CISADM>
• Enter the password for the cisadm user: <CISADM Password>
• Enter the name of the Oracle Database Connection String:
• On-premises: <DB_Server:DBPORT/ORACLE_SID>
• ADB: @<tnsname>?TNS_ADMIN=<wallet location>
Installing the Oracle Utilities Customer Care and Billing Database Component
Note: The Oracle Utilities Customer Care and Billing database component can be installed using OraDBI.java. While prior versions of the product have included OraDBI.exe, this is no longer supported going forward as this does not support latest functionality/features introduced in OraDBI.java. OraDBI.jar is delivered in directory jarfiles.
Installing the Oracle Utilities Customer Care and Billing Database Component Using OraDBI.java
OraDBI.java is a new tool to install and upgrade database components. It can be run from UNIX or Windows server that has the following installed:
• Oracle 19c
• Oracle 19c client
Before installing the Oracle Utilities Customer Care and Billing V25.10, make sure the following prerequisites are met.
• JDK 17
• Oracle Database
• For ADB, the database connection should be working. For more information, see step 1.b.a.c in the Creating the Database section.
To install the Oracle Utilities Customer Care and Billing V25.10 database:
1. Unzip Oracle Utilities Customer Care and Billing V25.10 Oracle Database package.
2. Set JAVA_HOME, PATH, and CLASSPATH.
UNIX:
WINDOWS:
3. Run the following command from the command line or command prompt from the ..\CCB\Install-Upgrade folder.
UNIX:
WINDOWS:
• Enter your password for username CISUSER:
• Enter your password for username CISREAD:
UNIX:
• On-premises:
java -Xmx1500M com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DB_SERVER>:<PORT>/ <SID>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_US ER_ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
• ADB:
java -Xmx1500M com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_USER_ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
WINDOWS:
• On-premises:
"C:\Program Files\Java\jdk"\bin\java -Xmx1500M -cp C:\..\FW\jarfiles\* com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DB_SERVER>:<PORT>/ <SID>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_US ER ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
• ADB:
“C:\Program Files\Java\jdk”\bin\java -Xmx1500M -cp C:\..\FW\jarfiles\* com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_USER ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
This process generates log files in the directory ..\CCB\Upgrade\Install-Upgrade\logs.
-2016-05-23 16:31:38,315 [main] ERROR (common.cryptography.KeyStoreWrapperFactory) The keystore file ‘<filename>’ does not exist.…
Installing Oracle Utilities Customer Care and Billing Database Rollup
Important! Proceed with the steps in this section only if the installation package contains the CCB-V25.10-Database-Rollup-MultiPlatform folder. If none, skip this step and proceed to apply Oracle Utilities Meter Data Management.
Make sure Java 17 JDK is installed on the machine to use the commands. The JDK version that is supported for your platform should be installed.
To apply Oracle Utilities Customer Care and Billing V25.10 Rollup:
2. Apply CCB 25.10 Rollup from the ..\ CCB-V25.10-Database-Rollup-MultiPlatform\CCB2510-HFix folder.
Note: For ADB, the database connection should be working. For more information, see step 1.b.a.c in the Creating the Database section. export/SET TNS_ADMIN=<wallet location>.
UNIX:
sh ouafDatabasePatch.sh or ./ouafDatabasePatch.sh
WINDOWS:
a. Run the ouafDatabasePatch.cmd tool.
Installing the Oracle Utilities Meter Data Management Database Component
Note: The Oracle Utilities Meter Data Management database component can be installed using OraDBI.java. While prior versions of the product have included OraDBI.exe, this is no longer supported going forward as this does not support latest functionality/features introduced in OraDBI.java. OraDBI.jar is delivered in directory jarfiles.
Installing the Oracle Utilities Meter Data Management Component Using OraDBI.java
• Oracle 19c
• Oracle 19c client
Before installing the Oracle Utilities Meter Data Management V25.10, make sure the following prerequisites are met.
• JDK 17
• Oracle Database
To install the Oracle Utilities Meter Data Management V25.10:
Using UNIX machine
1. Unzip Oracle Utilities Meter Data Management V25.10 Oracle Database package.
UNIX:
WINDOWS:
3. Run the following command from the command line or command prompt from the ..\MDM\Install-Upgrade folder.
UNIX:
WINDOWS:
UNIX:
• On-premises:
• ADB:
WINDOWS:
• On-premises:
“C:\Program Files\Java\jdk”\bin\java -Xmx1500M -cp C:\..\FW\jarfiles\* com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DB_SERVER>:<PORT>/ <SID>,<DBUSER>,<DBPASS>,<RW_USER>,<R_USER>,<RW_USER_ROLE>,<R_US ER ROLE>,<DBUSER> -p <RW_USERPASS>,<R_USERPASS>
• ADB:
This process generates log files in the directory ..\MDM\Upgrade\Install-Upgrade\logs.
Optional: This optional step should be executed if you have installed Oracle Utilities Meter Data Analytics 2.5.0.0.2 (2.5 Patch Set 2), or if you plan to install it in the future.
Navigate to ..\MDM-V2.5.0.1.2-Oracle-Database-Multiplatform\MDM\Post-Upgrade folder and run Materialized_View_Creation.sql from sql prompt as follows:
a. Connect to Database Owner Schema. (example: <CISADM>/<CISADM>@<SERVICE_NAME>)
b. Run Materialized_View_Creation.sql as @Materialized_View_Creation.sql from sql prompt.
After the required changes are complete, configure security by following the steps in the Configuring Security section.
Installing Oracle Utilities Meter Data Management Database Rollup
Important! Proceed with the steps in this section only if the installation package contains the MDM-V25.10-Database-Rollup-MultiPlatform folder. If none, skip this step and proceed to apply Oracle Utilities Operational Device Management.
To apply Oracle Utilities Meter Data Management V2510 Rollup:
2. Apply MDM 2510 Rollup from the ..\ MDM-V25.10-Database-Rollup-MultiPlatform\MDM2510-HFix folder.
Note: For ADB, the database connection should be working. For more information, see the step 1.b.a.c in the Creating the Database section. And, export/SET TNS_ADMIN=<wallet location>.
UNIX:
WINDOWS:
Installing the Oracle Utilities Operational Device Management Database Component
Note: The Oracle Utilities Operational Device Management database component can be installed using OraDBI.java. While prior versions of the product have included OraDBI.exe, this is no longer supported going forward as this does not support latest functionality/features introduced in OraDBI.java. OraDBI.jar is delivered in directory jarfiles.
Installing the Oracle Utilities Operational Device Management Using OraDBI.java
• Oracle 19c
• Oracle 19c client
Before installing the Oracle Utilities Operational Device Management V25.10, make sure the following prerequisites are met.
• JDK 17
• Oracle Database
To install the Oracle Utilities Operational Device Management V25.10:
Using UNIX machine
1. Unzip the Oracle Utilities Work and Asset Management V25.10 Oracle Database package.
2. Unzip the WAM-V25.10-Database.zip package.
3. Set JAVA_HOME, CLASSPATH, and PATH.
UNIX:
WINDOWS:
4. Run the following command from the command line or command prompt from the ..\WAM\Install-Upgrade folder.
UNIX:
WINDOWS:
UNIX:
• On-premises:
• ADB:
WINDOWS:
• On-premises:
• ADB:
This process generates log files in the directory ..\WAM\Upgrade\Install-Upgrade\logs.
5. Make sure to check the log files for any errors.
-2016-05-23 16:31:38,315 [main] ERROR (common.cryptography.KeyStoreWrapperFactory) The keystore file '<filename>' does not exist.…
Installing Oracle Utilities Operational Device Management Database Rollup
Important! Proceed with the steps in this section only if the installation package contains the WAM-V25.10-Database-Rollup-MultiPlatform folder. If none, skip this step and proceed to apply Oracle Utilities Digital Asset Management.
To apply Oracle Utilities Operational Device Management V2510 Rollup:
2. Apply WAM 2510 Rollup from the ..\ WAM-V25.10-Database-Rollup- MultiPlatform\WAM2510-HFix folder.
UNIX:
WINDOWS:
Installing the Oracle Utilities Digital Asset Management Database Component
Note: The Oracle Utilities Digital Asset Management database component can be installed using OraDBI.java. While prior versions of the product have included OraDBI.exe, this is no longer supported going forward as this does not support latest functionality/features introduced in OraDBI.java. OraDBI.jar is delivered in directory jarfiles.
Installing the Oracle Utilities Digital Asset Management Component Using OraDBI.java
• Oracle 19c
• Oracle 19c client
Before installing Oracle Utilities Digital Asset Management V25.10, make sure the following prerequisites are met.
• JDK 17
• Oracle Database
• Schema (such as CISADM) should exist in the database.
• max_string_size is set to EXTENDED.
To install Oracle Utilities Digital Asset Management V25.10:
Using UNIX machine
1. Unzip the C2M-V25.10-Oracle-Database-Multiplatform.zip package.
2. Set JAVA_HOME, CLASSPATH and PATH.
UNIX:
WINDOWS:
3. Execute the following command from the command line or command prompt from the ..\C2M\Install-Upgrade folder.
UNIX:
WINDOWS:
UNIX:
• On-premises:
• ADB:
WINDOWS:
• On-premises:
• ADB:
This process generates log files in the directory ..\C2M\Upgrade\Install-Upgrade\logs.
Installing Oracle Utilities Digital Asset Management Database Rollup
Important! Proceed with the steps in this section only if the installation package contains the C2M-V25.10-Database-Rollup-MultiPlatform folder. If none, skip this step and proceed to the Post-Installation Tasks.
To apply Oracle Utilities Digital Asset Management V2510 Rollup:
2. Apply C2M 2510 Rollup from the ..\ C2M-V25.10-Database-Rollup-MultiPlatform\C2M2510-HFix folder.
UNIX:
WINDOWS:
ORADBI Performs the Following Tasks
• Interacts with the user to collect information about the name of Oracle account that will own the application schema (for example: CISADM), password of this account, and the name of the Oracle account that the application user will use (for example: CISUSER), and the name of the Oracle account that will be assigned read-only privileges to the application schema (for example: CISREAD).
• Verifies whether tablespace names already exist in the Storage.xml file (if not, the process will abort).
• Installs the schema, installs the system data, and configures security.
• Maintains upgrade log tables in the database.
• Updates release ID when the upgrade is completed successfully.
• If an error occurs while executing a SQL script or another utility, it logs and displays the error message and allows you to re-execute the current step.
Log files OraDBI###.log are created in the same folder as OraDBI and contains all the SQL commands executed against the database along with the results. The log files are incremental so that the results are never overwritten. If warning messages are generated during the upgrade, OraDBI prompts the user at the end of the process. Users should check the log files to verify the warning messages.
• Warning messages are only alerts and do not necessary mean a problem exists.
• Stores the Schema owner and password in the feature configuration table. The password is stored in encrypted format.
• OraDBI can be executed by a non-schema owner.
Enable USER_LOCK Package
For inbound web services to work the USER_LOCK must be enabled at the database level. This is a one-time step. If not already enabled, perform these steps to enable it:
1. Login as SYS user for on-premises and as ADMIN for ADB.
Note: For ADB, the database connection should be working. For more information, see the step 1.b.a.c in the Creating the Database.
2. On the SQL prompt, run:
@?/rdbms/admin/userlock.sql
3. Grant permission.
grant execute on USER_LOCK to public;
Please note that grant can also be made to the database user which the Application connects to only instead of to public. For example: cisuser
Generating Database Statistics
During an install process new database objects may be added to the target database. Before starting to use the database, generate the complete statistics for these new objects by using the DBMS_STATS package.
Creating Activity Statistics Materialized View (Optional)
To improve the performance of drill down queries, use the following procedure to create the materialized view and then refresh it.
1. Navigate to ..\ MDM\Post-Upgrade folder in Oracle Utilities Meter Data Management V25.10 Oracle Database package.
2. Login as CISADM user.
3. At the SQL prompt, run the following:
@D1_ACTIVITY_STAT_MV.sql
@D1_MV_REFRESH_PROC.sql
Creating Index D1T304S3 for Payload Statistic Functionality (Optional)
This index does not exist for an initial installation. If you are using the payload statistic functionality, create the index. Connect to CISADM schema and execute the following:
CREATE UNIQUE INDEX D1T304S3 ON D1_INIT_MSRMT_DATA
(IMD_EXT_ID,INIT_MSRMT_DATA_ID);
Setup Oracle Utilities Digital Asset Management Configuration
This section is mandatory for every Oracle Utilities Digital Asset Management installation.
Note: The script can be run from any machine that has Oracle client installed and can connect to the database.
1. Navigate to ..\..\C2M\Post-Install\ folder in Oracle Utilities Digital Asset Management V25.10 Oracle Database.
2. Login as a schema owner.
3. On SQL prompt, run the command below:
@DACS.SQL
Upgrade Install
This section describes how to upgrade the database components for Oracle Utilities Digital Asset Management, including:
Migrating from BYTE Based Storage to CHAR Based Storage
This section assumes that the database already exists for every Oracle Utilities Digital Asset Management installation using BYTE semantic.
1. Set nls_length_semantics=CHAR.
2. Restart the database.
3. Make sure nls_length_semantics is CHAR.
4. Export schema from the database that has nls_semantics_legth=BYTE.
expdp userid=system/<code>@<SID> directory=<DIR_NAME> schemas=<schema_name> dumpfile=<schema_name>.dmp logfile=<schema_name>.log
5. Generate DDL from dump file using Oracle impdp utility.
impdp userid=system/<code>@<SID> directory=<DIR_NAME> DUMPFILE=<schema_name>.dmp SCHEMAS=<schema_name> SQLFILE=<schema_name>_DDL.sql
6. Replace “Byte” with “Char” in <schema_name>DDL.sql.
For vi editor (in Linux), use the following command to replace Byte to Char.
:%s/BYTE/CHAR/g
7. Replace the schema name also if it is required for environment.
8. Run <schema_name>DDL.sql (generated in step 6) that creates objects in the schema.
To make sure the number of objects at source and target are equal:
SQL>select OWNER || ‘ ‘ || OBJECT_TYPE || ‘ ‘ || COUNT(*) || ‘ ‘ || STATUS FROM DBA_OBJECTS WHERE OWNER in (‘<SCHEMA_NAMe>’) GROUP BY OWNER, OBJECT_TYPE , STATUS ORDER BY OBJECT_TYPE;
9. If an object is missing for any reason, create it by fixing DDL manually (DDL for each object is available in the file which was created in step 6).
Run DDL for the objects that are not created.
10. Generate DDL to disable triggers using following command:
SQL> SELECT ‘ALTER TABLE’ || ‘ ‘ ||TABLE_NAME || ‘ ‘ || ‘DISABLE ALL TRIGGERS;’ FROM USER_TABLES;
11. Run the script generated from step 10 to disable all triggers.
12. Import the data only.
Note: For ADB, follow the instructions in the Importing the Demo Dump File section.
To import data only into the schema created to support CHAR based database storage:
impdp userid=system/<code>@<SID> dumpfile=<schema_name>.dmp CONTENT=DATA_ONLY SCHEMAS=<schema_name> LOGFILE=<schema_name>_import.log
13. Enable the triggers.
To generate DDL for triggers:
SQL>SELECT ‘ALTER TABLE’ || ‘ ‘ ||TABLE_NAME || ‘ ‘ || ‘ENABLE ALL TRIGGERS;’ FROM USER_TABLES;
14. Run the script generated from step 13 to enable all triggers.
By default the database is created with BYTE length semantics. This setting should be modified to use CHARACTER length semantics by setting NLS_LENGTH_SEMANTICS to CHAR at session level via a logon trigger during installation as shown below.
Example:
database
declare
begin
if ( user_name LIKE 'CISADM' or user_name LIKE ‘STG%’ ) THEN
execute immediate ‘alter session set nls_length_semantics=CHAR’;
END IF;
END;
Extended Datatypes
Important! This change in your database environment is mandatory. If not included it will lead to errors during the V25.10 upgrade.
Excluding Table/Index
To exclude an index or table during the upgrade process:
1. Edit the OraSchUpg.inp file in the Install-Upgrade directory.
2. Add the tables and indexes in the following format:
-INDEX: ‘INDEX_NAME’,’INDEX_NAME’
-TABLE: ‘TABLE1_NAME’,’TABLE2_NAME’
Example: To exclude the F1_WEB_SVC table:
-TABLE:’F1_WEB_SVC’
If there are multiple tables, include them with separated commas.
-TABLES: ‘TABLE-1’,’TABLE_2’,’TABLE_3’
Similarly for indexes:
-INDEX:’F1C064S1’
Granting Privileges to Database Roles
Before running the upgrade, make sure to grant the Create Synonym to the database read write (CIS_USER) and read only (CIS_READ) roles as SYS for on-premises and as ADMIN for ADB.
grant CREATE SYNONYM to CIS_USER;
grant CREATE SYNONYM to CIS_READ;
Enabling DBMS_RLS Package
Before installing Oracle Utilities Application Framework V25.10 make sure to provide execute privilege on dbms_rls package to CISADM user. Execute the following command as SYS for on-premises and as ADMIN for ADB.
grant execute on dbms_rls to CISADM;
Upgrading the Database Component
A successful database upgrade consists of the following steps:
Upgrading Oracle Utilities Digital Asset Management from V25.4 to V25.10
This section assumes that only Oracle Utilities Digital Asset Management exists on top of Oracle Utilities Application Framework.
Make sure to install Oracle Utilities Digital Asset Management in the order mentioned below:
• Oracle Utilities Application Framework V25.10 Database
Upgrading the Database as Non-Schema Owner
The product allows non-schema owners to run the database upgrade.
To perform the upgrade, the non-schema owner must have the following database grants:
• grant connect, CREATE SESSION to <Non-Schema owner>;
• grant select on <Schema owner>.CI_WFM to <Non-Schema owner>;
• grant select on <Schema owner>.CI_WFM_OPT to <Non-Schema owner>;
Upgrading the Oracle Utilities Application Framework Database Component
Installing Framework Prerequisite Database Single Fixes
Upgrading the Oracle Utilities Customer Care and Billing Database Component
Upgrading the Oracle Utilities Meter Data Management Database Component
Upgrading the Oracle Utilities Operational Device Management Database Component
Upgrading the Oracle Utilities Digital Asset Management Database Component
The post-installation steps are as follows:
Dropping Index D1T304S3 for Payload Statistic Functionality (Optional)
For an upgrade installation, this index already exists. If you are not using the Payload statistic functionality, or if you have no other SQL scripts referencing these fields, you may drop the index.
DROP INDEX D1T304S3;
Setup Oracle Utilities Digital Asset Management Configurations
Demo Install
This section describes how to install the demo database components for Oracle Utilities Digital Asset Management, including:
1. Download the Oracle Utilities Digital Asset Management V25.10 Oracle database from the Oracle Software Delivery Cloud.
2. Copy and extract the downloaded zipped file to your local machine.
Note: You must have Oracle Database Server 19c installed on your machine to create the database.
It is strongly recommended to use DBCA to create the database.
Refer to Creating the Database for steps to create the database.
Database Storage BYTE/CHAR
Database created by default will store data in BYTES. This setting should be modified to use CHAR length semantics. To store data in CHAR, follow these instructions:
Initial Install
2. Set nls_length_semantics=CHAR.
4. Make sure nls_length_semantics is CHAR.
Upgrade and Migration from BYTE Based Storage to CHAR Based Storage
For the vi editor (in Linux), replace Byte to Char.
:%s/BYTE/CHAR/g
8. Execute <schema_name>DDL.sql (generated in step 6) that creates objects in the schema.
Make sure the number of objects at source and target are equal.
9. If an object is missing for any reason, create it by fixing DDL manually (DDL for each object is available in the file created in step 6).
Execute DDL for the objects that are not created.
10. Generate DDL to disable triggers.
11. Run the script generated from step 11 to disable all triggers.
12. Import the data only into the schema created to support CHAR based database storage.
13. Enable the triggers. To generate DDL for triggers:
15. Run the script generated from step No.14 to enable all triggers.
Extended Datatypes
Note: This step is applicable for on-premises databases only. By default, ADB is set to EXTENDED.
Some of the Oracle Utilities Application Framework application table varchar2 fields require byte size beyond 4000 bytes to store data for new application requirements. To support this requirement the Oracle Utilities Application Framework database should use the Extended Data Types - Oracle database 12c feature (EXTENDED - the 32767 byte limit introduced in Oracle Database 12c applies.).
Important! This change in your database environment is mandatory. If not included, it will lead to errors during the V25.10 upgrade.
After the database is created successfully, import the demo data:
1. For on-premises database:
a. Set the correct ORACLE_SID and ORACLE_HOME.
b. Make sure max_string_size is set to EXTENDED.
c. Proceed to step 3.
2. For autonomous database (ADB):
a. Make sure the database connection is working. For more information, see step 1.b.a.c in the Creating the Database section.
b. Upload the dumpfile in OCI Storage bucket and obtain the dumpfile URL.
c. Create the cloud credentials in the database.
Note: Execute the script as a ADMIN user. The authentication token can be generated in User Settings in the OCI profile.
SET DEFINE OFF
BEGIN
DBMS_CLOUD.CREATE_CREDENTIAL(
credential_name => '<credential name>',
username => '<OCI Profile>',
password => '<authentication token>'
END;
d. Proceed to step 4.
3. Make sure max_string_size is set to EXTENDED.
4. Import the demo dump.
Note: Make sure the ..\DAM-V25.10-DemoData\Demo\exp_demo.dmp.gz file is extracted and available in data_pump_dir’s location before running the following import command.
On-premises:
impdp directory= data_pump_dir dumpfile= exp_demo.dmp logfile=exp_demo.log schemas=CISADM
ADB:
impdp USERNAME/password@<tns_name> directory=DATA_PUMP_DIR credential=<credential name> dumpfile=<dumpfile url in OCI> logfile=import_demo.log SCHEMAS=CISADM
5. After the import is complete, enable the DBMS_CRYPTO and DBMS_RLS packages. Execute the following command as SYS for on-premises and as ADMIN for ADB.
The configuration security utility and scripts are already part of the delivered jarfiles in ..\FW-V25.10-Oracle-Database-Multiplatform\FW\jarfiles directory. It can be run from a Linux or a Windows machine.
Note the following:
• Database vault must be disabled before running.
• Interactive mode for this utility is currently not working.
• -f parameter is not working and will be deprecated soon.
The utility configures security for the application owner schema objects.
Oragensec, by default, grantS permissions to CIS_USER and CIS_READ roles. To use site-specific roles, execute Oragensec after providing the command line options and specifying the specific roles.
OraGenSec Java Usage
java OraGenSec [-a <arg>] [-d <arg>] [-f <arg>] [-h] [-l <arg>] [-o <arg>] [-q] [-r <arg>] [-u <arg>]
OraGenSec Help
• -a <arg>: Generate security for all objects in the database
• -d <arg>: DB connection string as: $DB_USER,$DB_PWD,$DB_CONNECTION_STRING,$TARGET_SCHEMA
Note: Make sure the syntax for $DB_CONNECTION is as below:
• On-premises: jdbc:oracle:thin: :@<DB_SERVER>:<PORT>/<SID>
• ADB: jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location>
• -f <arg>: Generate security for specific objects from an input file
• -h: Print Help
• -l <arg>: Name of log file (optional)
• -o <arg>: Generate security for comma separated list of objects
• -p <arg>: Corresponding passwords of users to create synonyms for
• -q: Quiet mode
• -r <arg>: Roles corresponding to the users
• -u <arg>: Read Write user, Read Only user
To run the utility:
Note: For ADB, export/SET TNS_ADMIN=<wallet location>
1. Set JAVA_HOME, PATH, and CLASSPATH.
UNIX:
export CLASSPATH=/../FW/jarfiles/*
WINDOWS:
2. From any directory you can execute Oragensec as long as Step 1 is done. Run the following command:
UNIX:
• On-premises:
java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec-d <DBUSER>,<DBPASS>, jdbc:oracle:thin:@<DB_SERVER>:<PORT>/
<SID> -u <RW_USER>,<R_USER> -r <RW_USER_ROLE>,<R_USER_ROLE> -a A -p <RW_USERPASS>,<R_USERPASS>
• ADB:
java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec-d <DBUSER>,<DBPASS>, jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -u <RW_USER>,<R_USER> -r <RW_USER_ROLE>,<R_USER_ROLE> -a A -p
WINDOWS:
• On-premises:
“%JAVA_HOME%”\bin\java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec -d <DBUSER>,<DBPASS>, jdbc:oracle:thin:@<DB_SERVER>:<PORT>/
• ADB:
“%JAVA_HOME%”\bin\java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec -d <DBUSER>,<DBPASS>, jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -u <RW_USER>,<R_USER> -r <RW_USER_ROLE>,<R_USER_ROLE> -a A -p
