Custom Look and Feel Options
The default look and feel of the application can be customized via feature configuration. The base product is provided with a Custom Look And Feel Feature Configuration type. If you define a feature configuration of this type, you can adjust the look and feel in the following ways.
- You may adjust the look and feel of the application using cascading style sheets. Refer to User Interface Style Customization for more information.
- You may adjust configuration related to the display of the UI Map Help icon.
- You may choose to change the UI View Settings for all users in the system. To do this, define an entry for the UI View option type and enter the desired value. Note that individual users may override this setting on their user preferences.
