Extract Using File Integration
The product provides separate configuration that may be used to define how to extract the data and how to format it. This configuration provides more metadata related to defining how to get the data to extract and how to format the data. You may have many use cases where using this configuration rather than having all the logic directly in the Process Records algorithm is beneficial.
The configuration can support simple extracts, containing a single record type and possibly a header or footer record. It also supports more complex integrations, involving multiple record types and parent/child relationships between the records.
File Integration Type Configuration
The file integration type which describes and classifies the extract configuration.
The file integration record where the sequence, format and logic to extract the data required for a given record type are captured.
The file integration type defines the integration classification. Currently, only Extract is supported. In addition, the file integration type can be assigned to a category. The category may be used to identify extracts with a common purpose or target such as collection agency referrals. Your edge product may deliver a number of categories or you may define your own.
The system provides a business object for extract file integration types ( F1-ExtractFileIntegrationType ) that is expected to be used for most use cases
File Integration Record
The file integration record is the object that is responsible for defining a record's format and capturing the record details. A separate integration record must be defined for each record type included in the extract.
The record sequence defines the order that records are processed by the system. The parent sequence defines the record type of which this record is a child. Child records may also be referenced as a parent of lower level child records. The base Process Records algorithm provided by the framework processes all child records of a record type before processing the next record type in sequence.
Each file integration record references a data area that defines the extract record’s format, allowing the data to be extended. The Extract Records algorithms are responsible for populating the data area. The file integration record supports multiple extract processing algorithms so that the custom information can also be populated.
The extract record plug-in also supports the functionality described in the Flexible File Name / Writing Multiple Files topic.
The system provides a business object for extract file integration records ( F1-ExtractFileIntegrationRec ) that is expected to be used for most extract record use cases.
Configuring an Extract Process Using File Integration Type
The following points summarize the additional steps needed to implement a new extract background process that uses a file integration type to define the specific functionality:
Choose or create data area objects to define the extract record formats.
Define the logic required to populate each extract record type. Your edge product may deliver suitable plug-ins or you may need to create a plug-in script where the algorithm entity is File Integration Record - Extract Record. Note that the Extract Record plug-in receives most of the information defined in the Batch Control - Process Records plug-in.
Define the algorithm type and algorithm for each newly created script.
Choose or create a category for the file integration type using lookup FILE_INT_OBJ_FLG.
Create the file integration type and configure the file integration records using the defined data areas and algorithms.
Create a batch control by duplicating the appropriate base template for an extract background process. Include the File Integration Type parameter (fileIntegrationType) on the batch control and reference the appropriate file integration type.
Plug in a Process Records algorithm that reads the file integration type configuration and processes the record types. The system provides a base file integration record extraction algorithm (F1-FILEX-PR) that is expected to be used for most file integration plug-in extract processes.
Extending a File Integration Extract Process
Your edge product may deliver file integration types and batch controls designed for standard extract processes. However, extending the delivered extracts to add custom data is common practice for most implementations. You can customize the output from a delivered extract by:
Identifying the record types that need additional details
Creating a data area that defines the additional details and using that to extend the data area configured on the record type
Creating a File Integration Record — Extract Record plug-in script, algorithm type and algorithm that populates the extra details
Adding the algorithm to the integration record’s extract algorithms collection
In some cases, you may wish to extend the extract by adding additional record types. To do this, add your custom file integration records to the file integration type, following the steps described in Configuring an Extract Process Using File Integration Type.
