Message Sender - Main
To define a new sender, open
Description of Page
Enter a unique Message Sender and Description.
Set Invocation Type to Real-time.
Indicate the Message Class for this sender, which indicates the method used to route the message. The valid sender classes are as follows:
| Message Class | Description |
| RTEMAILSNDR | Email sender. |
| RTHTTPSNDR | HTTP sender. |
| RTJMSQSNDR | JMS queue sender. |
| RTJMSTSNDR | JMS topic sender. |
| RTJSONSNDR | HTTP JSON sender. |
| SOAPSNDR | HTTP SOAP sender. |
Indicate whether or not this sender is currently Active.
For JMS related senders, indicate whether the Message Encoding is ANSI message encoding or UTF-8 message encoding. (Note that for all other types of senders, the Character Encoding context type is used to configure encoding.)
If the Message Class is one that connects to a JMS Queue or JMS Topic, indicate the appropriate JMS Connection
If the Message Class is one that connects to a JMS queue, indicate the name of the JMS Queue to define where the message is to be sent.
If the Message Class is one that connects to a JMS topic, indicate the name of the JMS Topic to define where the message is to be sent.
