Sidebar Toggle
Click the Sidebar Toggle icon on the application toolbar to open or close the Sidebar Area. The image displayed depends on your sidebar's configured location and whether it's visible or collapsed.
| Location / State | Icon |
| Left / Visible |
| Left / Collapsed |
| Right / Visible |
| Right / Collapsed |
| Keyboard Shortcut |
| Alt+J |
Note: Refer to Shortcut Key Summary for information about the
alternate shortcut.
Closing the sidebar suppresses the refresh of the zones within the sidebar based on updates to the context. Opening the sidebar bar restores the display of the sidebar portal. Maximizing the sidebar then refreshes the zones with the latest appropriate content.
Your user preferences record is updated with the current state of the sidebar.
