Deploying the Jar File
To deploy the jar file:
- Download the GIS JAR file available as part of patch provided for the BUG 38333265.
- Copy the file to the server where ArcGIS is installed and unzip it.
- Navigate to the /GPService/lib/spl-w1–25.10–gis.jar file.
The deployment of this jar requires ArcGIS Desktop (to execute the jar and generate the results) and ArcGIS Server (to publish the results as Geoprocessing service).
This jar file should be placed in the following ArcGIS desktop and ArcGIS server running locations:
- ArcGIS Desktop installation folder path
Example: C:\Program Files (x86)\ArcGIS\Desktop10.8\java\lib\ext
- ArcGIS Server installation folder path
Example: C:\Program Files\ArcGIS\Server\usr\lib\ext
