Maintaining Timesheets
The Timesheet portal is used to display and maintain a timesheet record.
Refer to About Timesheets for more information.
You can access the portal from Menu, select Work Management, then select Timesheet. You are brought to a query portal with options for searching for a specific timesheet. Once a timesheet has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Timesheet Display: This zone displays information about the timesheet. This zone displays the status, employee, and time period of the timesheet. Timesheet summary section displays a chart that includes the craft and regular, overtime, and total hours summarized for the timesheet.
- Timesheet Detail Quick Add: This zone enables a user to quickly enter timesheet details.
- Timesheet Details: This zone displays information from the timesheet details.
The following zones may appear as part of the portal's Log tab page:
- Timesheet Log: This zone displays log details for the timesheet.
- Approval Request History: This zone displays approval service histories for the timesheet.
