Reference Summary Zone
This zone presents a graph that illustrates the number of objects referencing the current project and sub-projects. The references for each object are categorized into three groups based on their respective business object lifecycle stages.
Activities
Activities refer to both Regular Work Activities and Construction Work Activities that are associated with the current project and sub-projects.
| Regular Work Activity | Initial | Planning |
| Active | Pending Approval, Approved, Rejected, Active, In Progress, Sent, In Progress (External), Finished, Completion Error | |
| Final | Completed, Canceled | |
| Construction Work Activity | Initial | Planning |
| Final | Closed, Cancel |
Other Direct Charges (ODC)
Other Direct Charges refers to ODC Detail (Equipment and Other Resource) records that are associated with the current project and sub-projects.
| Other Direct Charges EquipmentOther Direct Charges Other Resource | Initial | Planning |
| Active | None | |
| Final | Posted, Canceled |
Permits
Permits refer to both permits associated with the current project and permits for activities associated with the current project and sub-projects.
| Reference Object | Category | Statuses |
Internal Permit External Permit |
| Active | Pending Approval, Rejected, Approved, Suspended, Active | |
| Final | Expired, Closed, Canceled |
Purchase Orders
Purchase Orders refer to the purchase order lines associated with the current project and sub-projects.
| Purchase Order Line (Craft, Equipment, Other Resource and Stock Item) | Initial | Created |
| Active | Ready for Revision, Revised, Approved, Issued | |
| Final | Canceled, Closed |
Purchase Requisitions
Purchase Requisitions refer to the purchase requisition lines associated with the current project and sub-projects.
| Purchase Requisition Line (Craft, Equipment, Other Resource and Stock Item) | Initial | Created |
| Active | Approved | |
| Final | Canceled, PO Processed, Blanket Contract Processed, Sent to External System |
Timesheets
Timesheets refer to the Timesheet Detail records associated with the current project and sub-projects.
| Timesheet Detail | Initial | Created |
| Active | None | |
Work Designs
Work Designs refer to both Work Designs and Template Construction Work Orders that are associated with the current project and sub-projects.
| Work Design | Initial | Created |
| Active | Pending Approval, Approved, Rejected, Work Generated | |
| Final | Canceled, Closed | |
| Template Construction Work Order | Initial | Created |
| Active | Active | |
| Final | Inactive |
Work Orders
Work Orders refer to both Regular Work Orders and Construction Work Orders that are associated with the current project and sub-projects.
| Regular Work Order | Initial | Planning |
| Active | Pending Approval, Approved, Active, Reopened, Rejected | |
| Final | Completed, Closed, Canceled | |
| Construction Work Order | Initial | Planning |
| Active | Pending Approval, Approved, Active, Rejected | |
