Template Construction Work Activities
Template construction work activities are the activities associated with a template construction work order. Template construction work activities are added to the template construction work order and are generated when the construction work order is created. Fields defined on the template work order activity would default to the construction work activity when created. For example, a Project number defined on the template construction work activity would be defaulted on the construction work activity created from that template. In this way template construction work activities can be reused to help your organization avoid repeat planning of the same work for similar jobs. Template construction work activities can also be added to non-final construction work orders using the Add Activity or Add Activity(s) From Template Construction Work Order hyperlinks from the Construction Work Order Activity Info zone on the construction work order.
User is required to define a short Description, select an active construction-related Activity Type, and add the number of Activation Lead Days to the record. Users must also select a Service Class which is used to derive the cost center and cost summary information.
At least one template construction work activity that contains CUs must be included on the template construction work order record.
