Maintaining Expedite Purchase Orders
The Expedite Purchase Order portal is used to display and maintain expedited purchase order records.
Refer to About Purchasing for more information.
You can access the portal from Menu, select Purchasing, then select Expedite Purchase Order. You are brought to a query portal with options for searching for a specific record. Once an expedited purchase order has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Expedite: This zone displays expedite information associated with the purchase order.
