Account Center
The Account Center allows customers to view and change information about their utility account, their alert preferences, and the communications they receive from the utility.
Login Details
Login details options to change the login email and password
Manage Recipients and Preferences
This image shows the account center that enables users to manage preferences.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Enable Contact Channels
Use this configuration property to specify which channels are made available in the account center.
Default: By default, this option is set to email, sms, and voice.
Optional
Choose one of the following:
Use the default option
Make these channels available:
Hide Login Details
The Login Details options must be hidden for utilities that do not implement single sign-on authentication.
Default: Show login details.
Optional
Hide login details
Change Product Names and Order
The product names, and the order in which they are listed, can be changed. Product names are changed by overriding message properties, while the order is specified in the configuration options.
Default order and naming:
  • Home Energy Reports
  • Weekly Energy Updates
  • High Bill Alerts
  • Peak Pricing Alerts
  • Rate Coach Emails
Optional
  • Use the default names and order
  • Use the following names and order:
Allow Add/Edit of Recipients
Specify whether to hide the ability to add and edit recipients. For utility customers who manage their own customer preferences, it is recommended that you set this option to hide the add/edit functionality.
Default: Customers are able to add and edit recipient details.
Optional
  • Use the default option
  • Hide add/edit recipient functionality
