Bill Comparison
The Bill Comparison allows customers to compare their current bill to their previous bill and to the corresponding bill from the same time period the previous year.
Bill Comparison Example
The following image shows a standard example of the Bill Comparison.
This image is an example of the bill comparison, including a bar graph and descriptive details that compare a customer's current bill charges to a previous bill.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Bill Used in Bill Comparison
The widget can be configured to display the comparison between the current bill and the same bill in the previous year by default. For example, if the bill for July 2016 is the current bill, it will be compared to the bill for July 2015. The standard default is to compare to the previous bill as a customer is more likely to have this historical data, while the customer may not have a full year's worth of data to display the same bill from last year.
Default: Compare current bill with most recent previous bill.
Optional
Choose one of the following:
  • Use the default option
  • Compare current bill to same bill last year
Rounding Cost Values
Rounding of costs for the bill comparison values may be disabled. This does not affect the values displayed for individual charges.
Default: Round bill comparison costs to the nearest dollar.
Optional
  • Do not round costs
Default Fuel Type for Dual Fuel Customers
The default fuel type for dual fuel customers can be set to gas.
Default: Use electric as the default fuel type for dual fuel customers.
Optional
  • Use gas as the default fuel type
Footer or Disclaimer
A brief message displayed at the bottom of the Bill Comparison.
Default: None.
Optional
  • Display a footer or disclaimer. Provide a short message to include in the footer or disclaimer.
Enable Water and Wastewater
If you integrate Bill Comparison with Digital Self Service - Transactions, comparisons are available to customers for water and wastewater service when applicable data requirements have been met.
Default: Disable water and wastewater
Optional
  • Use the default
  • Enable water and wastewater (only applicable when integrated with Digital Self Service - Transactions)
User Experience Variations
The user experience of the feature may vary for customers and utilities depending upon their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see Bill Comparison in the Digital Self Service - Energy Management Cloud Services Overview Guide and go to the User Experience Variations section.
