Energy Use Overview
The Energy Use Overview compares customers' energy use from their most recent bill period to their energy use in the same bill period from the previous year. An analogy insight may appear to help customers understand how their usage relates to real-world examples.
Energy Use Overview Example
The following image shows an example of the Energy Use Overview.
Example screenshot of the Energy Use Overview.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
1. Bill Period Labels Level of Detail
The amount of information to display on the bill period labels can be modified.
Default: The month is displayed for the bill period labels.
Optional
Choose one of the following:
  • Use the default option
  • Display both the day and month for the bill period labels
1. Bill Period Labels Date
The start or end date of a billing period can be used for the bill period labels.
Default: The bill period end date is displayed for the bill period labels.
Optional
  • Use the default option.
  • Display the bill period start date for the bill period labels.
Footer or Disclaimer (not depicted)
A brief message displayed at the bottom of the Energy Use Overview.
Default: None.
Optional
  • Display a footer or disclaimer. Provide a short message to include in the footer or disclaimer.
User Experience Variations
The user experience of the feature may vary for customers and utilities depending upon their service types (gas, electricity, dual fuel, and so on) and other factors. For more information, see Energy Use Overview in the Digital Self Service Energy Management Cloud Services Overview Guide and go to the User Experience Variations section.
