Usage Breakdown View
The Usage Breakdown view of the Data Browser allows customers to explore their top energy costs by disaggregation category (or "end use category") over time.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
General Configuration There are several general configurations you can make to the Data Browser, such as the order of the graphs or views, the default fuel or resource type selected, and the default time menu selected. See Data Browser for more details about what general configurations are available. |
Not applicable. |
Disaggregation for Solar Customers The widget can be configured to show a disaggregation for eligible net-metered solar customers. The explainer below the graph mentions solar panels, and the insight message changes slightly to imply that the disaggregation is based on an estimate. Default: Disabled. |
Optional
User Experience Variations
The user experience may vary for customers and utilities depending on their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see Usage Breakdown in the Digital Self Service - Energy Management Cloud Services Overview.
