Home Energy Analysis
The Home Energy Analysis is a visual, interactive survey that prompts customers to answer simple questions about their home attributes and energy habits. This information is used to provide customers with a more detailed breakdown of how they use energy.
There are two versions of the Home Energy Analysis. The way that the widgets are embedded varies slightly depending on which version is used. If you need help identifying which version is applicable to you, Contact Your Delivery Team.
