Create Additional Oracle Cloud Infrastructure Identity and Access Management Domains
A minimum of two dedicated Oracle Cloud Infrastructure Identity and Access Management domains are required for your Digital Self Service - Transactions integration. This separates users and configurations for production and non-production environments and ensures you utilize universal credits effectively.
The first domain that was provisioned as part of your cloud tenancy is used by your implementation and UAT Digital Self Service - Transactions environments, and is limited in functionality and number of supported users as a free service. You must provision a second domain for your customer production environment through a premium service of Oracle Cloud Infrastructure Identity and Access Management.
Note: If you intend to use a third-party identity provider for authentication in production, refer to Single Sign-On (SSO) Configuration.
To create your production domain, complete these steps in your Oracle Cloud Account:
  1. Open the navigation menu and select Identity & Security. Within Identity, select Domains.
  2. Select Create domain. The Create domain page opens.
  3. Provide the following information:
    • Display name: A descriptive name such as customerprod. Use only letters, numerals, hyphens, periods, or underscores. The name can contain up to 100 characters. Choose your display name carefully. Changing the display can cause additional updates such as updates to bookmarked URLs to use the new display name.
    • Description:  Provide a detailed description of the domain.
    • Domain type: From the available Domain Types, select External User. For additional information about domain types, see IAM Identity Domain Types.
    • Domain administrator: If you want to use your administrative user account for this identity domain, then clear the Create an administrative user for this account option. Otherwise, enter the details of the user you want to administer this identity domain.
    • Compartment: You have the option to choose a different compartment if required.
    • Show Advanced Options: To add tagging, select Show Advanced Options and enter the tagging details.
  4. Select Create Domain. You are now ready to configure the production instance like you did for implementation following the Oracle Cloud Infrastructure Identity and Access Management Product Configuration Steps.
Back to Top
