Peak Focused Normative Comparison
The Peak Focused Normative Comparison module educates customers about how their energy use compares to their neighbors. It compares the customer (“You”) to “Efficient Neighbors” and “Average Neighbors,” and provides the customer with an comparison state (such as fair, good, or great) to help them measure how their electricity use is compared to these neighbors. The results are displayed in a horizontal bar graph. Total electricity usage values are also displayed so the customer can have a better understanding of what their peak use is compared to their total use.
Appears in: Peak Focused Report
Peak Focused Comparison Example
The image below is an example of the peak-focused normative comparison.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Efficient Homes Color This bar displays a usage value for the most efficient 20% of the customer's neighbors. Default: Green |
Optional
Similar Homes Color This bar indicates how all the customer's neighbors are doing. Default: Gray |
Optional
Efficient Homes Label This bar displays a usage value for the most efficient 20% of the customer's neighbors. Default: Efficient Neighbors |
Optional
Similar Homes Label This bar indicates how all the customer's neighbors are doing. Default: Average Neighbors |
Optional
You Label This bar indicates how the customer is doing. Default: You |
Optional
Short Explainer The explainer text appears below the bar chart and includes an efficient homes description that defines the efficient neighbors the customer is being compared to. Default: "Efficient neighbors are the 20% of homes in your comparison group that used the least amount of electricity during on-peak hours this period." |
Optional
Fuel Explainer The fuel units used in the comparison are defined below the efficient neighbors description. Default: "A Kilowatt-hour (kWh) is the standard unit used to measure electricity use." |
Optional
Smiley Icons If smileys icons are configured, the icon set appears beside the main insight heading. Icon set options include:
Default: No icons (Off) |
Optional
Threshold When the cost/savings are not greater than the threshold, the fallback is used. Default: $100 |
Optional
Bottom Insight The utility may opt for a financial or percentage version of the bottom insight.
Default: Financial |
Optional
User Experience Variations
The user experience of the feature may vary for customers and utilities depending on their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see the Peak Focused Normative Comparison in the Oracle Utilities Opower Energy Efficiency Cloud Service Overview.
