Time of Use 101
The Time of Use 101 module educates customers about when electricity is most expensive based on their time of use rate plan. The module provides customers with information such as whether electricity prices differ on weekdays and weekends, how much more expensive peak prices are than off-peak prices, the hours during which electricity is most expensive, and a visual time line displaying off-peak, partial-peak, and peak hours.
Appears in: Time of Use Report
Time of Use 101 Example
The image below is an example of the Time of Use 101 module.
Image of the Time of Use 101 module
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Heading
The heading tells the customer that they can save money by using less energy during peak hours.
Default: "Save money by using less electricity during [peak hours]"
Optional
Choose one of the following:
  • Use the default header.
  • Provide alternate configuration.
Color Settings
Color settings determine the colors assigned to elements within the module.
Default: The default module colors are determined by the utility color pallet provided by the utility during Opower Platform configuration.
Optional
Call to Action Link Text
The call to action invites the customer to view their full plan details and provides a link to the utility's rate plan page.
Default: "View your full details of your rate plan."
Optional
  • Use the default.
Call to Action URL
Default: The URL links to the utility's rate plan page.
Required
Contact Your Delivery Team to discuss URL options.
User Experience Variations
The user experience of the feature may vary for customers and utilities depending on their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see the Time of Use 101 topic in the Oracle Utilities Opower Energy Efficiency Cloud Service Overview.
