Thermostat Adjustment Module
The Thermostat Adjustment module provides customers with a recommended thermostat adjustment for the season in order to align their settings with the U.S. Department of Energy recommendations. It also encourages the customer to purchase a smart thermostat in order to automate savings on cooling.
Appears in: Seasonal Report
Module Label: The label identifies the season applicable to the thermostat adjustment. For example, "This Summer."
Header: The header encourages customers to adjust their thermostat setting while away from the home to save energy.
Image: An Illustration is paired with large number call out of degrees to raise the thermostat.
Recommended Adjustment: The recommended adjustment tells the customer how they should modify their thermostat as recommended by the Department of Energy.
Details: The details encourage the customer to make saving energy easier by purchasing a smart thermostat so that they can automate their thermostat adjustment.
Requirements and Limitations
Fuel: Gas-only, electric-only, and dual fuel.
Recommended Data: AMI, Appliance Detection and Disaggregation data.
Data History: At least 13 months of data history.
Billing Frequency: Monthly, bi-monthly, or quarterly.
