Peak Focused Normative Comparison
The Peak Focused Normative Comparison module educates customers about their energy use relative to other homes during on-peak periods. The module compares the customer (“You”) to their neighbors, “Efficient Neighbors” and “Average Neighbors,” and provides them with a comparison state (such as fair, good, or great) to help them measure how their electricity use is compared their neighbors. The results are displayed in a horizontal bar graph. Total electricity usage values are also displayed so the customer can have a better understanding of what their on-peak use compared to their total use during the bill period. An informational text below the bar graph explains that "Efficient Homes" represent the 20% of similar homes in the customer's comparison group that used the last amount of energy in the billing period, and provides information about how the graph works. Depending on the customer's comparison state, the insight statement below the graph either gently informs the customer that savings are still within reach or informs them that they are leading their neighbors in savings.
On this page:
Requirements
Utility Requirements
Category |
Description |
Required Cloud Service |
Energy Efficiency Cloud Service |
Scale |
Not applicable. |
Customer Requirements
Category |
Description |
Billing Frequency |
Monthly, bi-monthly, or quarterly. |
Data Delivery Frequency |
Data Requirements |
Data History |
A minimum of one historical bill. |
Data Coverage |
AMI data for on-peak periods must have 100% of available reads for the customer. |
Supported Fuels |
Electric-only. |
Limitations
- Peak Focused Report: This modules is only available as part of the Peak Focused Report.
Time of Use Rate Plan: This module is only available to customers with a Time of Use rate plans.
User Experience
This section describes the user experience for a customer with a good data state.
User Experience Variations
Configuration Options
| Configuration Option | Input Value |
Efficient Homes Color This bar displays a usage value for the most efficient 20% of the customer's neighbors. Default: Green |
Optional
Similar Homes Color This bar indicates how all the customer's neighbors are doing. Default: Grey |
Optional
Efficient Homes Label This bar displays a usage value for the most efficient 20% of the customer's neighbors. Default: Efficient Neighbors |
Optional
Similar Homes Label This bar indicates how all the customer's neighbors are doing. Default: Average Neighbors |
Optional
You Label This bar indicates how the customer is doing. Default: You |
Optional
Short Explainer The explainer text appears below the bar chart and includes an efficient homes description that defines efficient neighbors that the customer is being compared to. Default: Efficient neighbors are the 20% of homes in your comparison group that used the least amount of electricity during on-peak hours this period. |
Optional
Fuel Explainer The fuel units used in the comparison are defined below the efficient neighbors description. Default: A Kilowatt-hour (kWh) is the standard unit used to measure electricity use. |
Optional
Smiley Icons If smileys icons are configured, the icon set appears beside the main insight heading. Icon set options include:
Default: No icons (Off) |
Optional
Threshold When the cost/savings are not greater than the threshold, the fallback is used. Default: $100 |
Optional
Bottom Insight The utility may opt for a financial or percentage version of the bottom insight.
Default: Financial |
Optional
