The Web Services Home Page
The Web Services Home page comprises five regions:
- Called Services: This region lists the services that were called along
with such metrics as Minimum, Maximum, and Average execution times, number of
times called, and information about the last call. It also has the following
three command buttons:
- Add to Watchlist: You can select certain services to watch and click the "Add to Watchlist" button to add it to the Service Watchlist area.
- Refresh: Refreshes the Called Services table from the server.
- Reset Statistics: Resets all the counters to zero; it will also re-initialize the Called Services list.
- Service Watchlist: This table displays the list of services that you would like to watch. It supports a Delete button to remove the service from the watchlist.
- Graph Area: Displays the Status of the service. This is a customizable area in which the customer can add various monitoring charts. By default it displays the Status of the Business Application Service.
Like other monitoring pages in this release, this UI is customizable. The user can customize the UI by clicking the Customize icon at the top right hand corner:
Both the layout and content of the page can be changed.
