Adding Metadata.xml
The final step in creating an OEM-compliant service pack is to create a Metadata.xml file and include it in the new service pack zip.
These steps need to be carried out on the host on which the OEM agent has been installed and on which the Enterprise Manager for Oracle Utilities plugin is deployed.The following image illustrates the contents of the final compliant service pack zip:
