The Software Development Kit Client
The Software Development Kit client is installed in
SDK/<version>
The SDK folder has the following scripts at the top level:
Additionally, a copy of Eclipse is installed later into the
eclipse
directory.
Note: Updates are unique versions of the Software Development Kit and therefore
have their own directories.
Note: A separate copy of Eclipse is installed per version of the Software Development Kit client because each version may have its own set of plug-ins and the
plug-ins must be in the plugins directory of Eclipse.
These files are not meant to be executed directly by the developer and are intended to be executed through scripts in the shortcuts folder.
The setsdkenv.bat
script specifies the OUAF SDK version and installation
folder.
The setplenv.bat
scriptsets up the environment variables needed to correctly
run a development environment for the application server.
Note: A copy of Eclipse is installed later into the
eclipse
directory.
This folder is created when the user first runs the startEclipse shortcut script. A
each version may have its own set of plug-ins, and the plug-ins must be in the
plugins
