General guidelines
  • Do not use reserved java words.
  • Do not use spaces.
  • Do not abbreviate.
  • Do not use punctuation.
  • Do not start the name with a number.
Here are our project guidelines for naming properties:
  • Generally, do not abbreviate. The exceptions are SA, and SP, for when the name would get too long if written as is. For example: ServiceAgreement, as part of a much longer field name.
  • In line with the above, spell out amount and total.
  • Boolean values (SW) are prefixed with is, has, can, are, or should, according to what is grammatically correct.
  • Date fields end with Date.
  • Time fields end with Time.
  • Datetime fields end with DateTime.
  • Id is spelled Id.
  • Do not include a final Flag (FLG) or Code (CD).
  • Use min instead of minimum, and max instead of maximum.
  • Can be generic. That is, for the field BILL_STATUS, you can just name it status.
