Batch Program reindexJavadoc.bat
| Property | Detail |
| Purpose | Recreate the Javadoc indices. |
| Description | This script recreates the Javadoc indices so that it shows all of the Javadocs in the Javadoc folder. If Javadocs have been generated for CM code, this will update the indices to include both the CM and the product's classes and packages. |
| Usage |
| Parameters | None. |
