Maintaining Background Processes Overview
Each new background processes require the creation of two new classes: a
BatchJob
and a ThreadWorker
. These classes fit
into the master-worker pattern used by the background process runtime
infrastructure to overcome the throughput limitations encountered by single-threaded
processes. By splitting work among many concurrent threads, often on multiple physical
nodes, background processes can achieve excellent scalability and react to changing work
demands without additional programming. In this pattern:
- A
BatchJob
is responsible for determining the work to be processed for a batch run and then splitting that work into pieces that eachThreadWorker
will process. When running a single process, a singleBatchJob
object is instantiated by the framework. The framework then makes calls to theBatchJob
instance at the appropriate time. One such set of calls to theBatchJob
instance is to return to the framework a collection ofThreadWork
instances that will be distributed for execution. - A
ThreadWorker
is responsible for processing a singleThreadWork
instance for a run. Within theThreadWork
, there are manyWorkUnits
representing the fine-grained units of work to be processed. In many cases, theseWorkUnits
represent a complete database transaction. For example, a bill being created for an account, whether or not theThreadWorker
executes on the same computer as otherThreadWorkers
, or theBatchJob
that created its work is left as a configuration choice to be made at runtime. Within a single process, there may be manyThreadWorker
objects. In general, eachThreadWorker
instantiated in a batch run has a corresponding row in the Batch Instance table. The Batch Instance rows provide persistent state that is needed for theThreadWorkers
to operate correctly in failure/restart situations.
