Standard Business Methods
In general, classes that are created to implement business logic, including change handlers,
business entities, maintenance classes, and business components have access to standard
methods intended to give application code access to framework
functionality. Commonly, these classes extend the GenericBusinessObject
class within their inheritance hierarchy. Below are some general descriptions of the
provided methods. Refer to the JavaDocs for more detail.
createQuery(String)-Create an HQL query.createPreparedStatement(String)-Create a "raw" SQL statement. It is preferable to use thecreateQuerymethod.getActiveContextLanguage()/getActiveContextUser()-Get the language and user associated with the current request.createDTO(Class)-Create a newDataTransferObjectinstance for the entity corresponding to the provided business interface class.getDynamicComponent(various)-Get a Business Component instance corresponding to the input business interface for the component.getSystemDateTime()-Get the currentDateTimeinstance appropriate for business logic.IsNull(Object)/notNull(Object)-Methods that answer the question if an object is null or is equivalent to null.isNullOrBlank(String)/notBlank(String)-Methods that answer the question if a string reference is null, zero length, or all blank.startChanges()/saveChanges()-Used to defer validation when making complex changes to entities. It may be the case where a valid entity can only be constructed by passing through one or more invalid states. By callingstartChanges()at the beginning of the set of changes andsaveChanges()at the end, some validations may be deferred until the entire coherent change is complete.
