Timing code ('shootout'):
The code below will run a BO Update 100 times and report the amount of time taken. Note the 5 "warmup" executions before the repeated 100 runs.
			    public void testMultiplePluginScripts() throws Exception {
			        String docString1 = "<DR_ShortCreateIntervalRecords><factId>219250542869</factId><longDescr>REEE</longDescr></DR_ShortCreateIntervalRecords>";
			        Document doc1 = DocumentHelper.parseText(docString1);
			        String docString2 = "<DR_ShortCreateIntervalRecords2><factId>219250542869</factId><longDescr>REEE</longDescr></DR_ShortCreateIntervalRecords2>";
			        Document doc2 = DocumentHelper.parseText(docString2);
			        // warmups
			        for (int i = 0; i < 5; i++) {
			            BusinessObjectDispatcher.execute(doc1, BusinessObjectActionLookup.constants.FAST_UPDATE);
			            rollbackAndContinue();
			            BusinessObjectDispatcher.execute(doc2, BusinessObjectActionLookup.constants.FAST_UPDATE);
			        long totalElapsed = 0;
			        // speed
			        for (int i = 0; i < 100; i++) {
			            long start = System.nanoTime();
			            flush();
			            totalElapsed += System.nanoTime() - start;
			        System.out.println("Script (100): " + totalElapsed / 1000000 + "ms");
			        totalElapsed = 0;
			            flush();
			        System.out.println("Java (100): " + totalElapsed / 1000000 + "ms");
