Data Objects
Both PageHeader and PageBody are "wrappers" on underlying
Maps that hold datatypes of various types, keyed by field names (strings). The valid
field names for a service are described in the service meta info file (an xml document).
Null values are not allowed; use empty strings to represent missing values (for null
date, for example).
Note that most system datatypes are represented in these Java objects as simple strings. Note the following:
- Booleans are represented by the Java Boolean class.
- Date values are represented as Strings in the format YYYY-MM-DD.
- Date/Time values are represented as Strings in the format YYYY-MM-DD-HH:MM:SS.
- Time values are represented as Strings in the format HH:MM:SS.
- BigInteger values are represented as Java BigInteger values.
- BigDecimal and Money values are represented as Java BigDecimal values, with the appropriate scale.
