Guidelines
Applying a CM patch install package to QA or production app servers is the same as for release install package. That is, it is done simply by executing the install tool from the the package directory.
By using these scripts, implementation developers can prepare an installation package containing the contents of their custom modifications.
Developers need to build a packaging environment on a server of the same operating system
platform as used by the target environment to create CM release packages. A version
number must be used to identify each custom modifications (CM) release version. Once
developers select a version number format, the version number must be stored on the
environment in the file $SPLEBASE/etc/CMVERSION.txt, to achieve this
place CMVERSION.txt file in etc subdirectory in your
patch directory.
$isExpanded environment
variable is set to false), in which case it is not possible to just
manually copy changes to the directories.
