Oracle Utilities Application Framework API Reference Guide
Introduction
What are the Public APIs?
What are Not APIs?
Changes and Deprecations
OUAF Release 4.0.0.0
com.splwg.base.domain.common.algorithm.Algorithm. getActiveVersion
com.splwg.base.support.algorithm.AbstractAlgorithmComponent. setAlgorithm
com.splwg.base.support.algorithm.AbstractAlgorithmComponent. setParametersFrom
OUAF Release 4.0.2.0
com.splwg.base.support.FrameworkSession.clear
com.splwg.base.support.FrameworkSession.flush
com.splwg.base.domain.common.maintenanceObject. MaintenanceObjectInfomationAlgorithmSpot.setEntity
java.util.HashSet Behavior Change
OUAF Release 4.1.0.0
Deprecation: com.splwg.base.api.batch.AbstractThreadWorker.rollbackToSave Point
Deprecation: com.splwg.base.api.batch.AbstractThreadWorker.setSavePoint
OUAF Release 4.2.0.0
com.splwg.base.api.batch.AbstractThreadWorker.getActiveBatch Thread
com.splwg.base.support.context.FrameworkSession. getConnection
OUAF Release 4.2.0.1
Bug Fix: com.splwg.base.support.context.HibernateCacheHelper. flushAndClear
Bug Fix: com.splwg.base.api.PreparedStatement (Constructor)
OUAF Release 4.2.0.2
Bug Fix: com.splwg.base.domain.common.masterConfiguration. MasterConfiguration_Id (Constructor)
Bug Fix: com.splwg.base.domain.common.businessObject. MessageRepository.businessObjectStatusOptionReplacedBy
OUAF Release 4.3.0.0.0
com.splwg.base.domain.common.businessObject. BusinessObjectEnterStatusAlgorithmSpot
com.splwg.base.domain.common.businessObject. BusinessObjectExitStatusAlgorithmSpot
Bug Fix: JS API - handleExpand/handleCollapse Methods in xslInclude.js
OUAF Release 4.3.0.2.0
Removed Two-decimal Money Limitation
OUAF Release 4.3.0.4.0
API to access Oracle JET
OUAF Release 24.1.0.0.0
Enhanced Composite ID Class Generation to Output Optional ID Constructors
Oracle Utilities Application Framework 25.4 API Reference Guide
