Lookup Naming Guidelines
Here are guidelines for naming Lookups (on the Lookup Field maintenance):
- Be specific. The name MUST be unique across all lookups.
- Do not include a final standard suffix Flag or Lookup (The suffix Lookup is automatically added by the generator to the classes generated for each Lookup field.)
Examples:
WO_STATUS_FLG->writeOffStatus -
STM_RTG_METH_FLG->statementRoutingMethod
Here are guidelines for naming Lookups Value properties (on Lookup Value maintenance):
- Try to word the name in a way that makes sense when prepended by is, and is
also valid when standing alone as a constant. For example,
{isComplete, COMPLETE},{isFrozen, FROZEN}. - The name might match the English description of the lookup value.
Examples:
HOW_TO_USE_FLG : -->subtractive -
ITEM_STATUS_FLG : A->active -
DGRP_PRIO_FLG : 10->highest10 -
DGRP_PRIO_FLG : 20->priority20
