Extract From Release/Patch Install Package
To extract the source from a release or patch install package, specify the data directory in the install package as the
source directory. For example, the following invocation extracts source from a patch
install package named CM1.0_1
in the C:\CMInstall
directory into C:\CMExtract
and marks the extract as version
CM1.0_1
perl extractCMSource.plx -s C:\CMInstall\CM1.0_1\CMCCB\data
-d C:\CMExtract -v CM1.0_1
