Property Configuration
Control of log4j occurs based on properties typically set in the
log4j.properties file in the application classpath. You can change
the log level of a given logger in this file. Note, however, that values may be
overridden on the command line by specifying system properties (for example, via
-Dlog4j...). Note that inheritance of logger levels works such that
(in our standard of qualified class name as the logger name) you can change a whole
package's log level by specifying only a portion of the logger name. Note that you may
commonly desire to enable global debug logging on your local environment. To do this,
you can simply change the line:
logger.spl.level=info
to
logger.spl.level=debug
Changing the log is not recommended.
