Create an External User Exit
The following example shows the process of creating an external user exit. In this example, we would like to disable the
Start Date
on the
Pay Plan
page and default it to "today's" date.
Find the Name of the JSP File
Determine the Base User Exit
Uncomment the Function and Add Code
Test Your Code
Parent topic
UI Javascript User Exits
This site works best with JavaScript enabled
