Defining Generator Tools Metadata
Before generating new programs, you must create the metadata to be used by the generator tools.
Warning:
Please refer to the System Table Guide for the standard naming convention of each metadata object below. Compliance to the standard naming conventions is critical in ensuring the ability to upgrade.
Parent topic
